Author Topic: Johnie's 76 GL1000 Sulfur Yellow Build  (Read 21763 times)
Offline Johnie
Re: Johnie's 76 GL1000 Sulfur Yellow Build
« Reply #100 on: April 30, 2023, 05:12:46 PM »
Current pics showing the numerous unused fairing wiring I removed. Got all the blinkers and wiring installed. This week plan to flush cooling system and install new radiator hoses. Then install the handle bar wiring, order master and caliper kits.
« Last Edit: April 30, 2023, 05:16:06 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline BenelliSEI
  • 1969 cb750
« Reply #101 on: April 30, 2023, 05:16:52 PM »
Did you pop the timing belt covers and check the belts and tensioner? Your shop looks very “comfortable”.
« Reply #102 on: April 30, 2023, 09:32:17 PM »
Nice looking workspace and fun SS under cover.
That's a lot of wiring ...
Definitely check the belts and tensioner.
Scotchbrite pads can give a good approximate of the satiny finish many times Honda used on cast parts
Offline newday777
« Reply #103 on: May 01, 2023, 01:53:51 AM »
Looking at the belts won't do much. If the belts are over 5 years old they need replacement as the rubber hardens up and the bends get set, belt failure is bound to happen at the worst of times and high cost to rebuild the motor is not worth the $50 savings......unless you like playing Russian Roulette.
Stu
My current rides
Prior bikes....
Offline Alan F.
« Reply #104 on: May 01, 2023, 02:54:50 AM »
They give the same advice at Goldwingdocs, if you don't know the age of your belts swap them out until you do.
« Reply #105 on: May 01, 2023, 06:44:47 AM »
Belts can be automotive store source, NGW group will have info on Gates part numbers/auto application.
Tensioner, South Sound Honda order...
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #106 on: May 01, 2023, 07:53:01 AM »
Easy to change too.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Johnie
« Reply #107 on: May 01, 2023, 07:57:27 AM »
Can I remove and replace the timing belts without messing up the timing? Should be easy enough to do as the radiator is coming out.
Oshkosh, WI  USA
« Reply #108 on: May 01, 2023, 08:00:43 AM »
Citric Acid crystals soak in hot water overnight will eat any deposits in radiator while not affecting the metal. You can get 5 pound bag on Amazon fairly cheaply. Used in beer making and canning...
Offline grcamna2
« Reply #109 on: May 01, 2023, 09:32:47 AM »
Yes,there are timing marks on the camshaft sprockets and it's an easy job.
The OEM timing belts have excellent markings/lines;they line-up great:they don't really seem necessary if you've done a couple of these but helpful for a 'first timer'.
Offline Johnie
« Reply #110 on: May 01, 2023, 09:40:10 AM »
Correct...this will be a first time for me doing timing belts.
Oshkosh, WI  USA
Offline Bankerdanny
  • Endeavor to persevere
« Reply #111 on: May 01, 2023, 09:44:24 AM »
You can get the belts at any auto parts store. There is a tutorial over at the NGW tech board. The hardest part of the job is getting the damn covers off, not a lot of room to get a wrench on the nuts. Rad through the instructions, you need to secure the cam pulleys so they don't rotate when you release tension on the belts.
Offline Johnie
« Reply #112 on: May 01, 2023, 09:45:13 AM »
RAF said: Scotchbrite pads can give a good approximate of the satiny finish many times Honda used on cast parts
[/quote]Scotchbrite pads on the timing covers dry or with WD40?
Oshkosh, WI  USA
Offline grcamna2
« Reply #113 on: May 01, 2023, 09:47:07 AM »
Johnie,the OEM timing belts are very good.
There's a few different other ones you can get that will fit also.
I read about Subaru part# belts that will cross reference to fit too.
I think it's wise to get a pair of belts which have as good of quality/longevity as OEM Honda,which is why I mentioned the Subaru.
« Last Edit: May 01, 2023, 11:34:44 AM by grcamna2 »
Offline grcamna2
« Reply #114 on: May 01, 2023, 09:48:32 AM »
[/quote]
I prefer fine steel wool pads,it's just a bit more clean-up with the fine steel wool bits..
I like red Scothbrite on real heavy corrosion and the fine grey is excellent.
« Last Edit: May 01, 2023, 11:36:21 AM by grcamna2 »
« Reply #115 on: May 01, 2023, 09:50:04 AM »
[/quote]
With WD40, gives some lube for the work…
Offline BenelliSEI
  • 1969 cb750
« Reply #116 on: May 01, 2023, 10:02:22 AM »
Check the belt tensioner. The bearings are often gone in older ‘Wings.
Offline Alan F.
« Reply #117 on: May 01, 2023, 11:30:54 AM »
That's a good point I've never thought of. New tensioners are NLA, are the tensioner bearings replaceable?
Offline Johnie
« Reply #118 on: May 01, 2023, 12:12:22 PM »
With only 15,000 miles you really think I need to replace the tensioner?
Oshkosh, WI  USA
Offline grcamna2
« Reply #119 on: May 01, 2023, 12:15:14 PM »
The internal grease may have degraded.
Offline CaseyH
    • SOHC/4 Owners Club Forums
« Reply #120 on: May 01, 2023, 06:35:48 PM »
I replaced the belts and pulleys
The belts were Gates Belts Gates T274 Timing Belt
The pulleys I rebuilt using automotive pulleys bolted onto the original brackets.
If you do your research on the NG site There are some pretty good threads
https://ngwclub.com/forum/viewtopic.php?f=30&t=69958
This is build thread i posted.
Post #47 shows a picture of the completed belts and pulleys
« Last Edit: May 01, 2023, 06:39:46 PM by CaseyH »
Offline Johnie
« Reply #121 on: May 01, 2023, 07:04:40 PM »
Thanks for that post Casey. I joined NGW last week. I will be checking it out.
Oshkosh, WI  USA
Offline Johnie
« Reply #122 on: May 01, 2023, 07:08:09 PM »
The pic of the OEM seat in post #100...you may wonder why the back is up a bit. I just set the seat on there for looks so it's sitting up on top of the mounting bolts.
Oshkosh, WI  USA
Offline BenelliSEI
  • 1969 cb750
« Reply #123 on: May 01, 2023, 08:35:10 PM »
You’ll know when you look. If they’re dry and sticky.......
Offline Johnie
« Reply #124 on: May 05, 2023, 04:27:16 PM »
Today I removed the carbs. I was able to get 2 of the 4 slides out. The choke and those 2 slides are froze as are all the floats. Considering taking them to a friend or to Randakk's for intensive care cleaning and rebuild unless you guys give me other ideas to consider. I don't have an ultra sonic and these look much more complicated than the 750's. Drained the coolant and like the oil it was very clean. Sure looks like whoever put it away for the season had intentions to ride in the spring some 20 years ago. As long as I have the carbs out going to change the coolant line o-rings and thermostat.
« Last Edit: May 05, 2023, 04:41:06 PM by Johnie »
Oshkosh, WI  USA
