Author Topic: Johnie's 76 GL1000 Sulfur Yellow Build  (Read 21900 times)
Offline Johnie
Re: Johnie's 76 GL1000 Sulfur Yellow Build
« Reply #225 on: June 26, 2023, 11:02:01 AM »
Thanks for tuning in Prospect. Great looking GL there. What brand shocks you using? I am in the market. Was looking at Hagon, but at $300+ thought I’d check around. Possibly Progressives? I don’t want cheapos, but don’t think I need top of the line for my type riding.
« Last Edit: June 26, 2023, 11:17:09 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Johnie
« Reply #226 on: June 26, 2023, 11:13:16 AM »
Since I had the wheel just about off doing the rear caliper I decided it was a good time to add some Moly paste to the splines. They’re pretty clean as expected with only 15k on it. I see evidence of the wheel being off in the past.
« Last Edit: June 26, 2023, 02:03:47 PM by Johnie »
Oshkosh, WI  USA
Offline Prospect
« Reply #227 on: June 26, 2023, 07:11:16 PM »
I have stock shocks on the bike for now.
Are you going to be servicing the final drive (u-joint) unit?  Apparently the 76 has a grease point to grease the u-join but, from what I have read, it is not very effective in lubricating the area.  Better to take the whole thing apart.
« Last Edit: June 27, 2023, 05:55:26 AM by Prospect »
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #228 on: June 27, 2023, 06:41:36 AM »
How old is that tire ?
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #229 on: June 27, 2023, 07:56:52 AM »
Nice progress, looking better all the time.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline newday777
« Reply #230 on: June 27, 2023, 08:23:29 AM »
I better follow this thread! I have a 1982 GL1800 coming tomorrow I inherited from a friend who recently passed away from colon cancer. It's been parked for over 20 years, and he just parked it, no preparation for long term storage. Cliff.
GL1100....
Stu
My current rides
Prior bikes....
Offline Magpie
« Reply #231 on: June 28, 2023, 07:34:42 AM »
Yes, GL1100. I'm confusing it with my current GL1100.  ::)  Cliff.
Offline Johnie
« Reply #232 on: June 28, 2023, 03:54:42 PM »
Painted the valve cover badges. Just couldn’t put them back on with paint missing.
Oshkosh, WI  USA
Offline grcamna2
« Reply #233 on: June 28, 2023, 07:00:45 PM »
Looks good Johnie;what type of paint did you use ?
Offline Johnie
« Reply #234 on: June 28, 2023, 08:44:19 PM »
I used the Dupli-Color engine paint. Figured the cover may get warm.
Oshkosh, WI  USA
Offline grcamna2
« Reply #235 on: June 28, 2023, 09:19:57 PM »
That sure beats Testors or Revell model paint !  :D
Offline Johnie
« Reply #236 on: June 29, 2023, 06:27:02 AM »
Geez I couldn't ever use that. I use Dupli-Color on all sorts of stuff. The adhesion is so good. I even used it on the inner fenders in the motor compartment of the Chevelle. These badges I masked off the chrome frame and sprayed the entire badge. Then used 3600 grit sand paper and a rubbing block to remove the paint from the chrome HONDA insignia.
« Last Edit: June 29, 2023, 06:28:47 AM by Johnie »
Oshkosh, WI  USA
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #237 on: June 29, 2023, 08:18:02 AM »
Nice job!
1973 CB 750 K3
Offline Johnie
« Reply #238 on: June 29, 2023, 08:54:05 AM »
So with rebuilding the entire master and calipers of front and back would you switch from DOT 3 to 4? Your thoughts???
Oshkosh, WI  USA
Offline grcamna2
« Reply #239 on: June 29, 2023, 08:56:18 AM »
No problem.
Dot 3 and Dot 4 are very much the same;DOT 4 has a higher boiling point than Dot 3.
Do you use your brakes very hard? Dot 4    if you are always gentle/progressive with your brakes and clutch as most Touring riders are,and don't have many hills which require hard stops Or go at high speeds and then jamb the brakes down hard,then I believe Dot 3 is sufficient.
« Last Edit: June 29, 2023, 09:05:09 AM by grcamna2 »
« Reply #240 on: June 29, 2023, 08:59:22 AM »
Hi Johnie...how is that Chevelle?   You're about to be in the middle of your car season, lucky you.  I'm in boating season, too hot for the Corvette.
Offline newday777
« Reply #241 on: June 29, 2023, 09:56:38 AM »
Totally backwards. Need to use Dot4 for high speed braking......
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #242 on: June 29, 2023, 10:39:43 AM »
Do you use your brakes very hard? Dot 4    if you are always gentle/progressive with your brakes and clutch as most Touring riders are,and don't have many hills which require hard stops Or go at high speeds and then jamb the brakes down hard,then I believe Dot 3 is sufficient.  Dot 4 has a higher boiling point than Dot 3.
Stu,it looks like we're both saying the same thing?
Offline newday777
« Reply #243 on: June 29, 2023, 10:52:14 AM »
Ya. Now that I see the big space w/small letter on 'if' and no period punctuation after our Dot 4
made it confusing.
"Do you use your brakes very hard? Dot 4    if you are always.........."
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #244 on: June 29, 2023, 11:55:14 AM »
Ah yes,grammar ..  ::)
Offline Johnie
« Reply #245 on: June 30, 2023, 02:56:55 PM »
Which caliper brake pin grease do you suggest for this GL? My guess is the Dow…
« Last Edit: June 30, 2023, 02:58:28 PM by Johnie »
Oshkosh, WI  USA
Offline grcamna2
« Reply #246 on: June 30, 2023, 05:06:25 PM »
Sil-Glyde for the pins.
Offline Johnie
« Reply #247 on: June 30, 2023, 07:24:41 PM »
Hey Stev-o...yes we are in the middle of the car season. I'm going to be rebuilding the carb soon as I had an issue with the float sticking...of course when I was heading to a show. It's time...according to the PO it has been on there for about 15 years with limited miles and no issue. So I think it's time.
Oshkosh, WI  USA
Offline Johnie
« Reply #248 on: June 30, 2023, 07:29:01 PM »
Geez, glade I asked. Do I need the Dow anywhere? Like between the piston lip and back of the metal that the brake pad is glued too?
« Last Edit: June 30, 2023, 07:33:03 PM by Johnie »
Oshkosh, WI  USA
Offline grcamna2
« Reply #249 on: June 30, 2023, 07:31:52 PM »
Geez, glade I asked. Do I need the Dow anywhere? Like between the piston and back of brake pad to reduce squeal?
I remember a fellow on here a few years back using that special Dow grease on the piston rubber seal..
