Author Topic: Johnie's 76 GL1000 Sulfur Yellow Build  (Read 21797 times)
Offline Johnie
Re: Johnie's 76 GL1000 Sulfur Yellow Build
« Reply #275 on: July 08, 2023, 01:53:50 PM »
I do like the looks of the shocks too. I have the rear master and caliper rebuilt and installed. Front calipers are off and received my 4 new pistons a couple days ago. I just could not put bad pistons back on there.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #276 on: July 10, 2023, 07:43:23 AM »
Old brake pistons are the last thing I'd go to, good move.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline grcamna2
« Reply #277 on: July 10, 2023, 07:53:54 AM »
A caliper that uniformly releases from gripping the rotor,the way it was designed to.. is a performance improvement on our old bikes.
I once worked on bringing a persons GL1000 back into service after it sat for years;it was a real joy  8)
The customer had correctly prepared it for storage and then protected it properly  8) 8)
The only thing the brakes needed was to have the fluid changed;even the fuel system was completely drained !
Offline Johnie
« Reply #278 on: July 10, 2023, 06:22:22 PM »
Camna that sounds like it was a neat project. It’s neat how on the GL you can replace the front pads without removing the caliper. Brakes are rebuilt now I’m ready to install the timing belt covers, valve covers, radiator. Shocks are supposed to be here July 11th.
Oshkosh, WI  USA
Offline Johnie
« Reply #279 on: July 11, 2023, 06:30:15 PM »
Shocks arrived today from goldwingparts.com. I’m very happy with the fit and chrome finish. I wanted adjustable. Front and back brakes are done as are both MC’s. Next I move onto putting my polished timing covers and valve covers on.
« Last Edit: July 11, 2023, 08:20:13 PM by Johnie »
Oshkosh, WI  USA
Online BenelliSEI
  • 1969 cb750
« Reply #280 on: July 12, 2023, 05:32:09 AM »
Shocks look great!
« Reply #281 on: July 12, 2023, 06:33:06 AM »
Those are very nice shocks Johnie, hope you are happy with their handling. Given the positive reviews of other GW owners I bet you will be happy.
Offline Johnie
« Reply #282 on: July 14, 2023, 03:50:39 PM »
Going to use Honda Bond sparingly on a few spots of the timing covers to hold them in place when I install. In looking at the gaskets it appears Honda didn't put it all over both sides. I take it that's because it's mainly used to keep dirt and water out of the belt area. Also the valve cover gaskets had no sealant on either side...is that correct?
Oshkosh, WI  USA
Offline Johnie
« Reply #283 on: July 15, 2023, 12:18:31 PM »
As promised before I install the radiator here’s a pic of the polished timing covers in place.
Oshkosh, WI  USA
Offline grcamna2
« Reply #284 on: July 15, 2023, 12:48:24 PM »
Johnie,the bike is looking better and Better  8)
Looks like it will be soon and you'll take it for a ride;you don't want to miss riding it during the riding season.
« Last Edit: July 19, 2023, 09:14:02 AM by grcamna2 »
Online BenelliSEI
  • 1969 cb750
« Reply #285 on: July 15, 2023, 12:50:31 PM »
Looks great!
« Reply #286 on: July 15, 2023, 12:52:01 PM »
Those really pop, nice work!
« Reply #287 on: July 17, 2023, 08:28:48 AM »
Very nice attention to detail, Johnie.
« Reply #288 on: July 17, 2023, 03:18:25 PM »
Once Alan sends you the carb side trim pieces you will have more nice pieces to show...
Offline Magpie
« Reply #289 on: July 19, 2023, 08:46:27 AM »
Looks great Johnie! I think I better up my game. Cliff.
Offline Johnie
« Reply #290 on: July 23, 2023, 02:09:08 PM »
Today I removed the center and side stands, battery holder and the exhaust. Was going to hold off until winter, but easier to paint outside. Plan is to use scuff pads on the exhaust then use Duplicolor engine enamel. With just scuffing do you think I should primer it too? The black exhaust was it flat, satin or semi?
« Last Edit: July 23, 2023, 02:10:46 PM by Johnie »
Oshkosh, WI  USA
Offline newday777
« Reply #291 on: July 23, 2023, 02:15:08 PM »
Exhaust is flat black Exhaust paint.
Primer if rust showing.
Stu
My current rides
Prior bikes....
Offline Johnie
« Reply #292 on: July 23, 2023, 03:36:06 PM »
Thanks newday is exhaust paint same as Duplicolor engine paint? Is there a reason to separate the headers from the mufflers. Took them off as a unit.
« Last Edit: July 23, 2023, 03:37:42 PM by Johnie »
Oshkosh, WI  USA
Offline newday777
« Reply #293 on: July 23, 2023, 04:21:56 PM »
Exhaust paint has a higher temp rating.
Is there Exhaust donuts between the muffler and headers? If donuts, no paint is necessary where the donuts go.
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #294 on: July 23, 2023, 04:45:55 PM »
Get some satin black VHT exhaust paint.
Offline Johnie
« Reply #295 on: July 23, 2023, 05:10:12 PM »
Yes, there is donuts there. I do have a new set of donuts if I decide to separate the headers from the mufflers. Also have 4 new copper headers gaskets.
Oshkosh, WI  USA
Online BenelliSEI
  • 1969 cb750
« Reply #296 on: July 24, 2023, 10:30:07 AM »
Home Depot sells a black BBQ paint that works well too. I may have brought this up before, but while you have the headers away from the cylinder head, look closely down the first bend from the flange. The early bikes have a double walled down pipe and the inner pipe had a habit of overheating and collapsing in on itself. On my ‘76 one of them was almost 75% closed off and it never ran right. Someone told me about it and when I swapped in a good one, the engine came alive! Apparently it was a very common problem.
Online BenelliSEI
  • 1969 cb750
« Reply #297 on: July 24, 2023, 10:31:55 AM »
Originally those joints (header to muffler) had a very nice clamp too.
Offline Prospect
« Reply #298 on: July 24, 2023, 11:45:19 AM »
Keep them together. I had a very hard time getting them back together after I replaced the muffler.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline grcamna2
« Reply #299 on: July 24, 2023, 11:50:59 AM »
I have heard this problem before.
