« Reply #348 on: October 31, 2023, 05:37:09 AM »
Thanks for the feedback guys. As winter gets closer I will be working on the cut wires for the left switches and installing a new right switch. Carbs won’t be ready until spring. Will also try electrolysis on the gas tank. Never did that before and want to check it out.
Electrolysis works great and you can do it in place without removing the tank. I used a wet/dry vac to suck out the water mix through the float hole on the wing tanks.
Logged
Stu
My current rides
Prior bikes....
