« Reply #468 on: March 15, 2024, 02:08:37 PM »
To rinse the tank after the Evaporust treatment(full tank of Evaporust is important to get all the surfaces covered, I buy 5 gal cans of Evaporust from home depot online) then drain Evaporust back into a 5 gallon bucket. (Use a hand siphon pump to drain)
Get a 1 gallon garden sprayer, put in fresh diesel fuel and spray the tank all around to rinse well.(the oil in the diesel fuel will prevent flash rust). Do this by removing the fuel sensor to access the inside of the tank. You can use a brush to scrub the walls and ceiling of the tank too.
Then drain the diesel fuel into another clean 5 gallon bucket. You can let the diesel fuel mixture set in the bucket until the moisture settles to the bottom and after a few days I bucket out the clear diesel fuel into a diesel fuel container to reuse on next tank cleaning.
Use clean rags to wipe out any moisture and diesel fuel.
Then rinse again 2-3 more times with clean diesel fuel to get out all traces of moisture and wipe clean.
Then I coat the tank with fresh 2 stroke oil to preserve it. On your tank wipe it on with an oil soaked rag.
« Last Edit: March 15, 2024, 02:13:52 PM by newday777 »
Logged
Stu
My current rides
Prior bikes....
