Author Topic: Tank Emblem Removal?  (Read 470 times)
Offline sfhurst
« on: April 10, 2023, 10:56:37 PM »
The parts manual for my '72 350F clearly shows the emblem secured by two small screws through the "O" and the "D".  I have scratched off a bit of the paint but I don't see a screw head.  What am I missing?
Offline newday777
Re: Tank Emblem Removal?
« Reply #1 on: April 11, 2023, 01:08:50 AM »
Actually, it's not screws. There are what honda calls nuts. The emblem has pins that push into the "nut" #23, the push nut goes into a hole on the tank.
I have used a thin flexible putty knife to remove the emblems. Carefully slide the knife in behind the emblem and gently lift the knife outward using the tank as a lever point. Go in from both sides of the pins to Carefully pull the pin out so you don't break it off(plastic pins). The "nut" clip usually rusts if left out in moisture over the years but there are new retainer nuts/clips available. The nut/clip part number is 87311-634-600(pack of 4)
« Last Edit: April 11, 2023, 01:13:22 AM by newday777 »
Stu
My current rides
Prior bikes....
Offline sfhurst
« Reply #2 on: April 11, 2023, 09:03:15 AM »
Great info!!!  Thanks a bunch.
Offline newday777
« Reply #3 on: April 11, 2023, 01:24:59 PM »
You are welcome 😊
Stu
My current rides
Prior bikes....
