Thanks for sharing the tire video! I worked in the Gates Rubber plant when it was here in Denver, circa 1990s, building automation machinery (like in the video) for it, producing mostly rubber belts and the early cogged rubber belts. Yep, those big machines. My primary job was "making them go" and "make the machines test every quality check item", which included making the machines reject the bad ones. It was COOL. Dayton Rubber holds all that equipment today, in Ohio.
Even more fun, though, was building automation for making products that get...ummm...very big, very quickly and loudly, often destroying something else in the process. I especially liked attending the tests of the products that came out of these machines - usually with protective gear, from behind blast shields, with earplugs, helmets, and body suits...
