Author Topic: Here's my 73 750  (Read 2259 times)
Offline Mbanda
  • I'll be your huckleberry berry
    • Sohc
Here's my 73 750
« on: April 16, 2023, 05:30:21 AM »
So this is my new to me 73 cb 750 and I have an engine on the way! As of currently I'm waiting for a brake rod setup and a new chain. I'm excited I've always wanted to own one and now I do!
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Here's my 73 750
« Reply #1 on: April 16, 2023, 08:33:17 AM »
Welcome
What direction are you going? Stock?
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Alan F.
« Reply #2 on: April 16, 2023, 10:49:19 AM »
Looks to be hard-tailed, interested in hearing your plans.
Offline Mbanda
    • Sohc
« Reply #3 on: April 16, 2023, 12:07:50 PM »
Yes as of now I'm going to keep the engine stock. Yes it's a hard tail. I'm not sure if it's home brewed or a kit that someone put on. But I dig it  😀 only thing I've been struggling with really so far is the tank. I have one but from internet searching it seems to be a sportster tank that has some poor welds on it.
Offline Mbanda
    • Sohc
« Reply #4 on: April 16, 2023, 12:16:28 PM »
Here's more photos
« Reply #5 on: April 21, 2023, 09:00:14 AM »
Nice start!  Following.
« Reply #6 on: April 21, 2023, 10:01:26 AM »
Congrats on getting a 750 and welcome to the SOHC forum
Is the engine ready or will need rebuild?
Offline Mbanda
    • Sohc
« Reply #7 on: April 21, 2023, 09:17:33 PM »
Well I got my engine in fellas! Boy I never wanna do that again lol 😆 can anyone help me out I belive I have switched up the leads going to my spark plugs. If anyone can tell me what lead to which plug that'd be awesome
Offline Mbanda
    • Sohc
« Reply #8 on: April 21, 2023, 09:19:49 PM »
The original engine that was in it was blown up unfortunately. I'm pretty sure it's the engine that came with it as well. I'm going to rebuild it at a later date that way I have another back up engine.
Offline Alan F.
« Reply #9 on: April 21, 2023, 10:08:23 PM »
Sounds like good plan. Nice job getting the engine back in. There are Shop Manuals to download around here somewhere.
Offline newday777
« Reply #10 on: April 22, 2023, 03:43:44 AM »
Left coil is 1/4, the 1/4 coil has a blue wire plugged into it, the 2/3 coil a yellow wire.
Stu
My current rides
Prior bikes....
Offline Mbanda
    • Sohc
« Reply #11 on: April 22, 2023, 08:35:05 PM »
Okay awesome ! I belive the person who had this engine listed it wrong . I belive its a 76 engine but the Supersport model. It had studs for the exhaust that I converted over to the 73k exhaust flange and the points wires are blue and white l. Can anyone confirm?
Offline Mbanda
    • Sohc
« Reply #12 on: April 22, 2023, 08:50:23 PM »
Also so here is some pics I took right now of the exhaust and of the points wires on the outs9de of the cover and not the inside. I haven't looked yet the wife wants to spend some time together ...yuck lolol. I'll post on the points tomorrow and see if it's yellow underneath the cover
Offline Mbanda
    • Sohc
« Reply #13 on: April 23, 2023, 05:21:57 PM »
Points wires
Offline newday777
« Reply #14 on: April 23, 2023, 07:49:35 PM »
Points wires
The insulation looks bad
Stu
My current rides
Prior bikes....
« Reply #15 on: April 24, 2023, 07:08:32 AM »
Look up the engine VIN on the chart here to determine what year it is...
http://www.sohc4.com/cb750/cb750k/#serial-numbers
Offline MauiK3
  • A K3 is saved
  • Old guy
1973 CB 750 K3
Offline Mbanda
    • Sohc
« Reply #18 on: April 24, 2023, 06:55:52 PM »
Hey ! Any and all help is awesome! I don't know everything about these bikes but I do know some. This isn't my first time tearing one apart engine wise..but it is for wiring and such..but hey I got spark fellas wired up the points and hooked up the battery real quick 😎
Offline Mbanda
    • Sohc
« Reply #19 on: April 24, 2023, 06:57:40 PM »
Another shot of it
« Reply #20 on: April 25, 2023, 02:45:56 AM »
10% off lulu coupon code good through Friday the 28th is:
INBLOOM10
Offline Mbanda
    • Sohc
« Reply #21 on: April 28, 2023, 08:08:40 PM »
Got the carbs on and exhaust on
Offline richmagee7
« Reply #22 on: May 04, 2023, 03:37:39 PM »
Following.
Offline Mbanda
    • Sohc
« Reply #23 on: July 30, 2023, 08:07:58 PM »
Got another question. The oil tank that is pictured has a breather line at the top were the fill cap is located and it also has a long breather line that is on the left side of the tank and that originally plugged into the engine breather port on the lower back portion of the engine. My question is do I need to re attach this breather line or can I leave it left off ?
« Reply #24 on: July 30, 2023, 08:30:08 PM »
Your aftermarket oil tank appears to have the same separate vent line and connection to the spigot like an early stock tank. If the tank is indeed the same as stock on the inside, oil will occasionally drain out of that hose, so it should be connected to the spigot on the back of the engine so it can be returned to the crankcase instead of dumping on the ground.
