Author Topic: Carb Rebuilder Recommendations  (Read 364 times)
Offline C317414
« on: April 19, 2023, 12:56:54 PM »
I have a set of CB550F carbs that may need rebuilding.  I normally would tackle it myself, but I have way too many projects going on, including rebuilding a water-damaged kitchen.
Can any of you recommend a good carb rebuilder?  Is there one in the Washington State area?
I searched the forum, and found recommendations, but they were a few years old.
Thanks
Re: Carb Rebuilder Recommendations
« Reply #1 on: April 19, 2023, 01:22:08 PM »
We had two members that were good but they have moved on.
I believe Hondaman can help you, he's in CO.
http://sohc4shop.com/catalog/product_info.php?manufacturers_id=12&products_id=47&osCsid=98a175624c2eb434621f7e1b2ad63585
And member Scott recommends old skool carbs but Rick is no longer on eBay and not active on fakebook...
https://www.facebook.com/485002854895718/posts/i-am-done-with-ebay-i-will-only-sell-carb-rebuilds-from-here-prices-will-be-bett/3337693942959914/
Offline dusterdude
« Reply #2 on: April 20, 2023, 03:48:02 AM »
Theres a fellow named bear that does goldwing carbs,if you want his info let me know and ill dig it up
Sent from my SM-G973U1 using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Scott S
« Reply #3 on: April 20, 2023, 03:51:13 AM »
 Here's the current FB page for Rick at OldSkoolCarbs
https://www.facebook.com/profile.php?id=100063593139657
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #4 on: April 20, 2023, 06:42:03 AM »
Thanks Scott.   Do you know how much he charges for a basic cleaning/rebuild?
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: April 20, 2023, 04:14:07 PM »
Check out Mike Nixon. He has a website called “the Motorcycle Project”. Flawless work, have used him myself in the past.
Until a few years ago. Bought a really good ultrasonic tank and do my own.
« Reply #6 on: April 20, 2023, 07:19:45 PM »
What tank did you get? Mine is worthless. :(
Offline C317414
« Reply #7 on: April 20, 2023, 07:41:46 PM »
Thanks for all the recommendations!
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: April 20, 2023, 10:08:42 PM »
Big Ultra Sonic Tank
« on: February 06, 2023, 09:50:36 am »
QuoteModifyRemove
This Branson Tank holds about 24 litres of solution. It belonged to one of the guys I race with. Tim has a full service auto shop that keeps 5 mechanics and one apprentice very busy. The tank stopped working a few years ago and was one of the filthiest tubs I’ve ever seen. There was +1” of dried sludge in the bottom and even the outer case was black with grease (originally white). It’s been bugging me, just sitting there, getting kicked around.
Dragged it home last week and opened it up. Of course it’s filled with circuit boards and sealed components that could be part of the space shuttle. A few of the sensors that were glued to the bottom of the tank had pulled away, so repaired the obvious. Some basic testing gave me a clue. The main control is a Diehl T85 Type 600 switch. Up to 60 minutes of run time, or can be cranked to full, locked “ON”. Regardless of the setting, no continuity. Internet browsing shows the item is generally used in tanning beds and hot tubs. Not available locally and not cheap!
Scrounged around in my junk bins and found a new rocker switch, DPST. Rated at 20 amps/ 250 V. Hooked it up and and it all came back to life. Two hours of scrubbing and I have a tank that is four times the size of my mini “carb tank”.
Moral of the story: You don’t always have to be a Rocket Scientist to figure stuff out!
Modify message
View my post “Big Ultra Sonic Tank”. Excellent results.
« Last Edit: April 20, 2023, 10:10:27 PM by BenelliSEI »
Offline Scott S
« Reply #9 on: April 21, 2023, 04:34:31 AM »
 I think it varies depending on model, how dirty or damaged, etc. He's always been reasonable to me.
'71 CB500 K0
'81 Yamaha XS650
Offline WideAWAKE
« Reply #10 on: April 21, 2023, 07:20:39 AM »
I’ve had really good results with a machine like this and a soda blaster.
https://www.amazon.com/Ultrasonic-Carburetor-Cleaner-Digital-Commerical/dp/B07HRFDXS8/ref=mp_s_a_1_18?crid=5IAODQXFB4G7&keywords=ultrasonic+cleaner&qid=1682086453&sprefix=ultra%2Caps%2C264&sr=8-18
Offline Rosinante
  • All Generalizations are False
« Reply #11 on: April 21, 2023, 10:15:00 AM »
I just sent an email to North City Vintage Honda on Lake City Way in Seattle.  Jeremiah did a great job on my carbs years ago, but I am not sure they are still in business.  Will let you know if I hear back.
1978 CB750K
