If you do this, make sure you buy a gross of appropriately sized and good quality vacuum caps. Keep some under your seat. unlike the original screw, if the vacuum cap on your port leaks from cracks or swelling, etc., You will start to experience some issues. Exhaust popping and erratic idle at stops. I have done this on a couple of my bikes, and I do like it for syncing convenience. But just be aware of the symptoms of a bad vacuum cap as well if you’re going to do this.
