Author Topic: 76 Honda CB 750 Super Sport  (Read 988 times)
Offline rampage4six
  • Brett
  • Brett Smith retired Solicitor Brisbane Australia
« on: May 01, 2023, 01:50:01 AM »
I have 2 of these bikes having purchased a new 1 in 1976. Both are fully restored and would suit a Honda show room in 1976. I've been a member for a good number of years. I am having wiring issues upon replacing the RH switch. Of course the wiring colours are different. So far I've got the yellow and red to it's matching y/r. I have the black and red to same. However the new switch has a light green and red, a black and white, a black and a brown and white. What do they connect to ??? it's driving me mad as I cannot find an answer after hours and hours of searching. My switch is the one that has the kill switch, off/on and start button. Thank you in advance. my email address is bcsmith@iinet.net.au
Brett
Offline newday777
Re: 76 Honda CB 750 Super Sport
« Reply #1 on: May 01, 2023, 03:48:00 AM »
Welcome aboard the forum from just north of Boston(I looked at your other posts and you haven't introduced yourself and your bike in the new members section yet)
Is this the same bike you posted on in 2018 when you joined the forum and didn't reply back to the posts to say if you got it sorted?
http://forums.sohc4.net/index.php/topic,174180.msg2026836.html#msg2026836
I'm assuming from the wire colors you bought an aftermarket switch assembly??
Is your bike in this question a USA market bike or an Australian market bike?(makes a difference in wiring schematics)
Stu
My current rides
Prior bikes....
« Reply #2 on: May 01, 2023, 05:59:07 AM »
Is the switch in your other bike functional? If so, I'd simply use it as a pattern. Once upon a time I purchased a "replacement" switch only to learn it was NOT a replacement due to a wiring issue. I gave in and got a genuine part. Problem solved.
« Reply #3 on: May 01, 2023, 06:31:36 AM »
The starter switch button on the 750f has an extra function that shuts off the headlight when pressed to start so there is a different wire scheme there then earlier bikes to work around also.
Offline rampage4six
  • Brett
Re: Aussie 76 Honda CB 750 Super Sport
« Reply #4 on: May 01, 2023, 01:46:03 PM »
Thank you for your replies. I must have ovelokked replying to my last post. I had to get an auto electrician in the end. I don't know how he fixed it at the end of the day. My second bike here is imported from the USA as was the other.
Where can I purchase an origigal spec switch as I would prefer that? Do I understand that it as amayyer of trial and error . Many thanks.
Brett
Offline rampage4six
  • Brett
« Reply #5 on: May 01, 2023, 01:48:45 PM »
I've tried to complete the info on my persoanal info but what I know about computers I could write on the back of a stamp with a felt pen.I don't know what most of it means.
Brett
Offline rampage4six
  • Brett
« Reply #6 on: May 01, 2023, 02:07:23 PM »
Where can I find a new switch as this reproduction is too short....that's another problem. The wires willl all nee to lenghtened.
Brett
« Reply #7 on: May 01, 2023, 03:00:09 PM »
Yes I think some of the wires on the right hand control have to be able to route all the way down to the black plastic triangle junction box.
Offline newday777
« Reply #8 on: May 01, 2023, 03:19:21 PM »
Post a picture of your switch as you said it has 'on-off'.
Is that the headlight on off?
1976 didn't have an on off for the headlight,  but the 1975 did have the on off headlight switch.
Stu
My current rides
Prior bikes....
Offline rampage4six
  • Brett
« Reply #9 on: May 01, 2023, 04:08:27 PM »
Honda CB750 CB550 RH Reproduction HANDLE BAR SWITCH 35300-341-672 P     this the switch plenty on internet. I'm sorry but I don't know how to upload a photo. Thank you.
Brett
« Reply #10 on: May 01, 2023, 04:34:43 PM »
No on-off on the 1975 CB750F in the States
« Reply #11 on: May 01, 2023, 04:40:54 PM »
Partzilla
SWITCH ASSY., STARTER STOP
35130-377-670 Ships in 2 to 3 days$142.05
$132.11
https://www.partzilla.com/catalog/honda/motorcycle/1976/cb750f-a-750-super-sport/control-levers-switches-cables
Offline newday777
« Reply #12 on: May 02, 2023, 02:41:04 AM »
Have you tried at your local Honda shop? They are available at the dealers here in the states.
CMS also has them available.
35130-377-670 is the part number
Jerry
I didn't look up the part numbers before assuming..(bad on me) that because of K5 having had the on off headlight switch and the K6 having no on off that it was the same way on the 75F but you are indeed correct as the 75F uses the same part number as the 76F USA models, no on off headlight switch.
Stu
My current rides
Prior bikes....
« Reply #13 on: May 02, 2023, 04:27:00 AM »
For years, until I replaced all the wiring, I had wished it had the on/off switch! Damned weak charging systems  ::)
« Reply #14 on: May 02, 2023, 03:29:54 PM »
 I used a k4 switch on the F1 that I recently sold. I prefer control of the headlight, especially after I put a Euro style LED in the headlight bulbs park lamp.
Offline rampage4six
  • Brett
« Reply #15 on: May 06, 2023, 07:26:12 PM »
Gentleman it got the better of me in the end so I had to get a sparky in. He sorted it in 30 minutes. I'll post the wiring as soon as I unwrap it to confirm. The aftermarket loom is also about 3 inches too short(putting it inside the handlebar) so they all had to be lengthened. I don't have a headlight at the moment so if anyone knows the solution to that , that would be great.
I got eveything else in place just matching wire colours. Couldn't get the starter though. I'll unwrap today and post the answer but 2 wires from the switch had to be joined to the black.
Brett
Offline rampage4six
  • Brett
« Reply #16 on: May 06, 2023, 09:07:03 PM »
Here's the wash up.     yellow and red to yellow and red
                                  black and red to black and red
                                  black and white to black and white
                                  green and red to brown and blue and to 2 black
                                   brown and white is left free
Brett
« Reply #17 on: May 09, 2023, 09:50:14 AM »
 This is the 77F diagram. Some of the colors are difficult to see. So, still no starter or headlight?
http://oldmanhonda.com/MC/WiringDiagrams/CB750F(77).jpg
« Last Edit: May 09, 2023, 10:03:58 AM by Don R »
« Reply #18 on: May 09, 2023, 08:24:22 PM »
The Brown-White should mate to a Brown-White in the headlight bucket, enroute to the center fuse of the fusebox (which is under the bike's left side cover). Is there a loose Brown-White still in the headlight, coming from the back of the bike? It might possibly be a Brown-Red wire instead, as Honda sometimes altered this circuit's wire colors with no warning after 1975. This wire comes from the right handlebar to the middle fuse of the fuseblock, and then goes back to the headlight bucket to power the headlight via the left-side Hi/Lo switch.
