Author Topic: PD41A pump check ball size  (Read 666 times)
Offline Floshenbarnical
  • Money pit enjoyer
« on: May 04, 2023, 12:07:09 PM »
Hi friends, I've been lurking for a while but created a membership so I could use the search function to (hopefully) find the answer to this question. No luck.
When cleaning my carbs for my '77 Super Sport, I dropped the tiny pump check ball bearing and it disappeared forever. I ordered an assorted set of hardened steel ball bearings in metric sizing from 1-4mm, I'm wondering if anyone here knows what exact size they are. I have measured the hole but I don't want to throw a ball in there and have it get stuck or be too small and therefore not work properly. Scoured the internet and checked every manual I can get my hands on. No luck there either.
Many thanks for all the help I've gotten simply from reading through this forum, it's a total goldmine of info.
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline grcamna2
Re: PD41A pump check ball size
« Reply #1 on: May 04, 2023, 12:51:22 PM »
Welcome.  :)
 This is for the #2 PD carb accelerator pump;you're referring to the diaphragm cover with 3 screws,the small ball underneath the square part in the center which covers the ball in that 3-screw cover ??
75' CB400F/'bunch o' parts'
  • Money pit enjoyer
« Reply #2 on: May 05, 2023, 07:28:22 AM »
Thank you!
No. There's a similar one on rim of main float bowl on carburetor #2. I didn't actually check under the accelerator pump. I suppose they are most likely the same size, so I could measure that one ...
'77 CB750 SS
Offline grcamna2
« Reply #3 on: May 05, 2023, 08:51:25 AM »
Thank you!
Oh,ok I understand.
  • Money pit enjoyer
« Reply #4 on: May 08, 2023, 05:03:45 PM »
If anyone is curious it's 3.5mm
'77 CB750 SS
Offline grcamna2
« Reply #5 on: May 08, 2023, 05:19:12 PM »
3.5mm got it.
