Author Topic: Oil (?) in bottom of NOS gas tank  (Read 415 times)
Offline jwurbel
« on: May 13, 2023, 06:03:07 PM »
Got around to finally mount NOS tank that has sat in original box for last 35 years.  Found oil (?) in bottom of tank when I went to attach petcock.  I assume it was placed there to prevent rust?
Rinse out with gas or something else?
Offline newday777
Re: Oil (?) in bottom of NOS gas tank
« Reply #1 on: May 13, 2023, 06:20:09 PM »
Yes and yes
I put 2 stroke oil in after de-rusted to preserve the tanks I clean.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #2 on: May 13, 2023, 06:21:53 PM »
Back in the 70s the owners manual said for long term storage to empty the gas and fog the tank with light oil.
Stu
My current rides
Prior bikes....
Offline jwurbel
« Reply #3 on: May 13, 2023, 06:43:40 PM »
So just forget about it?
Offline Johnie
« Reply #4 on: May 13, 2023, 06:55:07 PM »
So outboard motor fogging oil is okay, right? Easier to use as it comes in an aerosol and you can cover the sides vs only the bottom.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Online CycleRanger
  • No comment about being an
« Reply #5 on: May 13, 2023, 07:02:25 PM »
There's nothing quite like that new tank smell!  ;D
Yeah, just rinse it out with a little gas and you should be good to go.
Offline Lucien Harpress
« Reply #6 on: May 13, 2023, 07:03:44 PM »
Yeah, it'll be fine.  The gas will dilute the oil well enough, and apart from MAYBE being a touch smokey for a little bit, the engine won't care.  Plenty of engines with bad valve seals burn oil just fine.
-1970 CB750 K0
-1980 KZ1300
-1976 Yellow GL1000
-1965 CA77 "Dream"
-1997 Valkyrie
-1975 Velosolex
Offline newday777
« Reply #7 on: May 13, 2023, 08:40:28 PM »
I just pour in a few Oz and swirl the tank around to coat all the surfaces.
Stu
My current rides
Prior bikes....
Offline chiefum
« Reply #8 on: May 13, 2023, 08:56:31 PM »
That's what I used on my chopper tank after cleaning it out.
