Author Topic: Aftermarket Tappet Caps  (Read 380 times)
Offline C317414
« on: May 19, 2023, 01:20:52 PM »
Hello
The tappet caps on my 75, CB550F are a bit chewed-up and the aluminum is stained.  I want to replace them all.  The last time I purchased aftermarket tappet caps for a Honda I was disappointed.   The caps did not quite look like the OEM caps.
Is there a source of aftermarket caps that look like the OEM caps?
Re: Aftermarket Tappet Caps
« Reply #1 on: May 19, 2023, 02:07:26 PM »
Nope, but if you can accept dull not shiney laquered Honda C90 are the same size but not polished
« Reply #2 on: May 20, 2023, 12:16:52 AM »
to avoid burring your new caps get a six sided 17mm socket and grind its opening flat on a belt sander or linisher to remove the lead in ramps like the one on the left,youll get a better bite on the thin hex aswell,dont use a socket like the one on the right with those stupid valleys between the flats,just a plain jane six sider!
Offline Tracksnblades1
« Reply #3 on: May 20, 2023, 05:59:39 AM »
You can do the same real quick on an old SouthBend or LaBlond.
Age Quod Agis
