Author Topic: Dad's 1978 Honda CB550k  (Read 20266 times)
Offline joegeis
  • '78 Honda CB550k
Re: Dad's 1978 Honda CB550k
« Reply #350 on: April 14, 2024, 12:51:57 PM »
hey all, wanted to give a quick update. Weather has been nice and the bike has been running pretty well. Needs a little ether to start when its chilly, but otherwise runs and rides. I've been enjoying just putting some miles on it so far this spring, but the bike is definitely not yet "finished" (if these bikes ever are). I'm still trying to procure an air cleaner cover / tool tray, the idle still walks a bit, and I've really noticed that the thing is leaking oil. After my 70 mile ride today, the oil pan, kickstand and portions of the bottom of the pipes were slick with oil. It isn't leaking while parked (in fact no drops under the bike all winter), but when running I can definitely see oil seeping from a few places. I think for now, I'll just keep riding it, and maybe towards the end of the season I'll start planning a tear down and rebuild (which I'm definitely anxious about doing!).
Hope everyone is enjoying spring and getting miles on their bikes!
Offline newday777
« Reply #351 on: April 14, 2024, 02:00:44 PM »
Check between the fins behind the the exhaust header and downward. Might be the rubber pucks in the head covering cyl head bolts leaking.
Stu
My current rides
Prior bikes....
Offline joegeis
  • '78 Honda CB550k
« Reply #352 on: April 14, 2024, 04:40:36 PM »
The fins on the front of the head, under the exhaust manifold were definitely covered in oil. I'm not sure what you mean by rubber pucks though.
Offline newday777
« Reply #353 on: April 14, 2024, 04:56:04 PM »
#14
https://www.southsoundhonda.com/--xpartsstream#/Honda_Powersports/CB550KA_(78)_550_FOUR_K%2c_JPN%2c_VIN%23_CB550K-2100001_TO_CB550K-2122082/CYLINDER_HEAD/0f12de96-474a-4fbe-a2ee-8ba2cda5f653/332fe051-e75f-419c-8695-482efb8d6689/y
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #354 on: April 14, 2024, 06:47:34 PM »
Here is a picture of my '76 CB550 head, see the 6 holes, flat rubber seals should go there after head is torqued down.
« Reply #355 on: April 15, 2024, 01:59:28 AM »
Also note, the ones from the dealer and similar sources have been too thin causing leaks...  Parts n more varies ones which are the correct thickness.
Offline joegeis
  • '78 Honda CB550k
« Reply #356 on: April 15, 2024, 08:04:40 PM »
great, thanks. I'll keep you guys posted.
Offline lazyMlazyK
« Reply #357 on: May 19, 2025, 10:05:34 AM »
Well, I hit my first challenge today. I goofed something up with the choke mechanism on the carbs (PD 46A). I was trying to gently separate the carb bodies far enough to replace the fuel tube, and while trying to wiggle it back together, something in the springs and gears shifted. My problem is that everything still LOOKS the same! I could see that potentially the light spring is looser. Perhaps it unwound a bit. However, the choke actuator is not really working at all now. Here are some photos and a video of me pulling the choke to the limit of how far it will go. You can see the choke flaps barely move, and that there is a difference between carbs 1&2 vs 3&4. Can anyone tell how to fix what I've botched up? VIDEO
How did you figure out how to fix your issue?  I'm currently going through a set of PD46A carbs, and I'm not sure how that spring setup is supposed to look between carbs 2 and 3. I'd like to separate all the carbs in order to replace the o-rings on the fuel tubes - thats the ONLY reason I'm separating these carbs.
Offline joegeis
  • '78 Honda CB550k
« Reply #358 on: May 19, 2025, 05:49:16 PM »
Honestly, I just kept tinkering with it, and trying to reference photos/manuals. I didn't take pictures of the springs specifically before disassembly, so I had to use other photos that I took with the springs not the focal point. I recommend taking really good pictures before taking it apart!
