Author Topic: Silicon Exhaust Sealant?  (Read 663 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
« on: May 25, 2023, 10:00:39 AM »
I used the sealant that came with the headers I bought from Delkevic (4-1) and ended up having to take the exhaust back off. Now that I'm ready to reassemble the exhaust, I was wondering if there were some options out there that are better than others (i.e Brand names, types of exhaust sealant, ect)?
Thoughts and opinions? 🤔
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
Offline denward17
Re: Silicon Exhaust Sealant?
« Reply #1 on: May 25, 2023, 10:09:00 AM »
No help, but where does this sealant go?
Offline Ellz10
  • ZZ
« Reply #2 on: May 25, 2023, 11:38:17 AM »
Around the outside of each of the 4 pipes at the tip that slides into the collector.
« Reply #3 on: May 25, 2023, 12:19:32 PM »
 I like the copper silicone gasket maker.
Offline Kelly E
  • Geriatric Hooligan
« Reply #4 on: May 25, 2023, 03:05:21 PM »
To me the Delkevik red exhaust sealant looks just like the red fire block sealant we used to use to seal holes where plumbing and wiring travel between floors of houses.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline Ellz10
  • ZZ
« Reply #5 on: May 25, 2023, 04:05:22 PM »
Because of the high temp rating or just in general?
That's funny because my old man said the same thing when he stopped by the first time I was applying it! He said it was like the stuff they used when plumbing.
Offline C317414
« Reply #6 on: May 25, 2023, 05:05:14 PM »
I've had good luck with Permatex high temperature silicone.  It's available in black, as well as red.
Offline Tracksnblades1
« Reply #7 on: May 25, 2023, 05:33:30 PM »
I doubt if any of the silicone sealers have a temperature rating much over 600*. And much lower for continuous exposure.
Age Quod Agis
Offline Kelly E
« Reply #8 on: May 25, 2023, 06:17:01 PM »
Delkevik has great customer service. The system for the 80' GS 1100E had a the welded on nut to attach the baffle broken free out of the box. Right away they sent us a new baffle for free and said keep the original one.
We ordered the system for the 77' KZ 1000LTD that didn't come new with a centerstand but has the mounting points. We put a centerstand on it so needed a centerstand stop. We contacted them and they sent a stop for free.
Call them, they'll probably send you a new tube.
1983 Honda CB 1100F
« Reply #9 on: May 26, 2023, 01:11:35 AM »
i use red or copper which ever i have on hand,clean with turps(turpentine) the area first and dry it,then with turps on a rag clean the excess once assembled,ive had it hold well for ages.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #10 on: May 26, 2023, 07:47:55 AM »
I'm not familiar with Delkevic but you need to put a sealer on parts when installing them. They must be down in the silencer
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline C317414
« Reply #11 on: May 26, 2023, 09:00:12 AM »
True, but it has always worked well and lasted for me on muffler/silencer slip joints.
« Reply #12 on: May 26, 2023, 10:09:54 AM »
Normally the temps at the silencers isn't in the 600F range. The catalyst if equipped has to be very close to the exhaust manifold because of the operating temperature they need to convert the exhaust gasses into acceptable emissions. But the mufflers are way hot enough to brand you but aren't operating in the 600F and above temps. Anyone got an IR temp gun they can take some reading of CB exhausts at various points?
Offline Ellz10
  • ZZ
« Reply #13 on: May 26, 2023, 01:56:44 PM »
Thank you everyone for your replies. I did end up going with Permatex's Muffler & Tailpipe Exhaust Sealant. It's rated at 2000° F, non-expanding, and a few other great qualities. It states it great for use at joining joints.
« Reply #14 on: May 26, 2023, 02:20:24 PM »
You sure that's removable? I think that hardens
« Reply #15 on: May 27, 2023, 02:27:53 PM »
I think the others were suggesting serviceable options.
In case you have to take it out and work on it..
But I like your confidence..😁
Age Quod Agis
Offline Ellz10
  • ZZ
« Reply #16 on: May 27, 2023, 05:26:52 PM »
Oh well that's not what I want then. It didn't state that it hardens or that it doesn't. Maybe I'll just contact Delkevic customer support for a new tube.
Yeah I definitely want to be able to service it down the road lol
« Last Edit: May 27, 2023, 06:50:48 PM by Ellz10 »
