Author Topic: Rear wheel offset?  (Read 458 times)
Offline JTJamhawk
Rear wheel offset?
« on: May 25, 2023, 01:41:57 PM »
Does the 1972 CB500 rear wheel have an offset?  My son and I bought a bike as a project but it is completely in pieces. It came with the hub and rims and we need to rebuild the hub and put spokes on.
Offline Kenzo1979
Re: Rear wheel offset?
« Reply #1 on: May 25, 2023, 01:43:28 PM »
There is a spacer
--Kenzo
** 71 CB500, 74 CB550, 76 CB400F, 77 CJ360t **
Offline Kenzo1979
« Reply #2 on: May 25, 2023, 01:47:02 PM »
Technically referred to as the collar.
--Kenzo
« Reply #3 on: May 25, 2023, 02:03:09 PM »
 If you mean hub to rim, I'd say no offset.
Offline JTJamhawk
« Reply #4 on: May 25, 2023, 02:38:08 PM »
Thanks! I was referring to whether there was a hub/rim offset.
« Last Edit: May 25, 2023, 03:14:34 PM by JTJamhawk »
Offline newday777
« Reply #5 on: May 25, 2023, 03:00:57 PM »
Thanks!
Clarify and answer the questions you have been asked. Others will need to know later on what the heck did that guy want to know and didn't give a hoot about what others  have asked of him to be clear ..........
Stu
My current rides
Prior bikes....
« Reply #6 on: May 25, 2023, 04:15:35 PM »
There is no offset rim to hub front or rear
Offline JTJamhawk
« Reply #7 on: May 25, 2023, 04:46:34 PM »
Thank you!
Offline Doobie
« Reply #8 on: May 28, 2023, 03:43:01 AM »
FYI, all you have to do is look at a parts diagram. Several sites such as CMSNL.com have them. Also, there is a tech doc section here with service manual and other useful info.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #9 on: May 28, 2023, 05:52:20 AM »
Non of them tell you if rim is offset to hub, only experience
Offline Doobie
« Reply #10 on: May 28, 2023, 07:20:44 AM »
Yeah, but they'll show if there's a spacer or collar, which is what I was referring to.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #11 on: May 28, 2023, 09:57:45 AM »
True Doobie but the op asked about rim offset, or at least that is what i understood
Offline Doobie
« Reply #12 on: May 28, 2023, 12:01:03 PM »
I think you understood better than me.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
« Reply #13 on: May 28, 2023, 01:14:24 PM »
England and America, two countries separated by the same language!
Offline thep1pe
  • Proud Owner 76 CB550F1
« Reply #14 on: May 28, 2023, 03:33:24 PM »
AFAIK no japanese bikes have an offset. It was a was easier to set the wheels without offsets and use a spacer to adjust the alignment laterally .
