Author Topic: Quick Question: F2 Copper Washers  (Read 351 times)
Offline spmc
« on: June 01, 2023, 05:41:12 PM »
I know the acorn nuts have the copper washers on them just wanted to check if it's necessary to replace those each time you fasten/unfasten or if they can be reused if they appear in good shape?
Re: Quick Question: F2 Copper Washers
« Reply #1 on: June 01, 2023, 06:24:34 PM »
I've never had any troubles with re-using them. If they have raised edges around where the nut previously pressed on them, just file them flat again. They will raise those edges again next time. too. They need to distort under toque to form the needed seal underneath them so oil doesn't weep down those particular studs.
Offline CycleRanger
  • No comment about being an
« Reply #2 on: June 01, 2023, 07:05:12 PM »
I usually anneal copper washers before reusing them.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: June 01, 2023, 07:24:56 PM »
+1 to that.
Offline spmc
« Reply #4 on: June 01, 2023, 10:05:23 PM »
Copy that! Had to look up annealing but I do have the technology so I will do that!
« Reply #5 on: June 02, 2023, 08:37:41 AM »
 We used to anneal copper head gaskets by coating them with acetylene smoke, then burning it off so we could see where we got it hot. A washer would be a lot easier.
