Author Topic: CB500 clutch adjustment tips and tricks  (Read 442 times)
Offline Scott S
« on: June 05, 2023, 02:47:22 PM »
 Got a nice ride on the '71 CB500 around the neighborhood today. The clutch is fine, but I feel like I could dial it in a little more. The biggest complaint is that it's engaging/releasing at the end of the lever travel a little more than I prefer.
 I've adjusted them before, but it's been a minute (went through a bunch of 550's). I know the procedure; I'm looking for those tips and tricks that everybody uses to get the 500 clutch "just right".
 And to answer the inevitable questions:
- OG Honda cable, moves freely
- Fresh oil
- clutch pushrod is in one piece
- I removed the worm gear on the side cover, cleaned it thoroughly, reassembled with fresh grease
-lubed the pivot pin on the lever
- unknown condition on the plates, 12K on the bike (no slippage that I can feel)
 Give me your secrets to a buttery smooth CB500 clutch adjustment!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Online dave500
Re: CB500 clutch adjustment tips and tricks
« Reply #1 on: June 05, 2023, 10:38:46 PM »
how worn is that corkscrew thread?often if real worn a fair bit of up n down motion takes place which removes some from the lateral motion,the soft alloy female part is still available i think,pretty sure the male hardened thread isnt?
Offline Deltarider
« Reply #2 on: June 05, 2023, 11:32:34 PM »
Whatever you do, realise that CB500s clutches are not particularly the lightest to operate and that's an understatment.
« Last Edit: June 05, 2023, 11:36:04 PM by Deltarider »
CB500K2-ED Excel black
Offline Little_Phil
« Reply #3 on: June 06, 2023, 02:27:04 AM »
The procedure says to turn the adjuster back 3mm before locking it off. Try varying this slightly. Maybe a little less, it's very sensitive.
Offline Deltarider
« Reply #4 on: June 06, 2023, 04:06:48 AM »
What you want to achieve the lightest possible operation is that the arm of the clutch lever is at a 90o angle when it actually operates the clutch. Unfortunately you will not be able to witness that, as it sits inside the cover  ;D. I've read somewhere, not that long ago, how somebody succesfully improvised a slightly longer arm for easier operation. May have been in the French forum.
Offline Deltarider
« Reply #5 on: June 06, 2023, 01:29:53 PM »
« Last Edit: June 06, 2023, 01:38:12 PM by Deltarider »
