Author Topic: Electrics - Only the Beginning Round 2  (Read 1580 times)
Offline redbaron
« on: June 15, 2023, 04:56:22 AM »
1976 CB550F - All wiring connections look good.  battery reading 12.88. I turn key and no lights,  I hit starter button and no sound, no start. I get 12.88 volts on positive going into solenoid.  With key on, I jump solenoid terminals and starter does nothing.  I replaced solenoid and still no start. I checked continuity from yellow/green wire from solenoid to starter button and have continuity.  I pulled off side cover and inspected starter and wires, they all look good with good ground from battery. I think right hand control/start button is aftermarket. Could this be a bad start button? Could this be a problem with ignition switch and wires/connections? Would a bad R/R cause this? What would you do next?
Re: Electrics - Only the Beginning Round 2
« Reply #1 on: June 15, 2023, 06:12:45 AM »
 I've seen a bad battery that read volts but had no power to do anything useful.
Offline redbaron
« Reply #2 on: June 15, 2023, 06:16:25 AM »
I turned ignition on and jumped solenoid. No start, but, when I hit start button the solenoid clicks. Here is photo of solenoid and wiring.
Offline newday777
« Reply #3 on: June 15, 2023, 06:17:07 AM »
Have you had the battery load tested?
Stu
My current rides
Prior bikes....
Offline redbaron
« Reply #4 on: June 15, 2023, 06:25:29 AM »
Where do I do that? The battery is new. I have another good battery I will check bike with.
« Last Edit: June 15, 2023, 06:41:40 AM by redbaron »
« Reply #5 on: June 15, 2023, 06:33:16 AM »
Local auto parts stores usually offer free battery testing...
Offline willbird
« Reply #6 on: June 15, 2023, 08:42:12 AM »
I would think if you have some copper wire and the headlight assembly you can just use the headlight by itself to see if the battery will at least light the headlight ?? it sounds like maybe it will not even do that ??
Offline redbaron
« Reply #7 on: June 15, 2023, 10:19:55 AM »
Battery checked good at advance auto. I get solenoid to click if I turn ignition on, jump screwdriver across solenoid poles, and hit start button. What else should I check?
Offline extrafunky
« Reply #8 on: June 15, 2023, 10:32:17 AM »
Starter motor is probably toast or not connected or loose ground. You can try connecting it directly to the battery to test. That is basically what you're doing to the + side if you short the solenoid terminals. Check the - battery post if connected to ground.
Offline redbaron
« Reply #9 on: June 15, 2023, 10:41:12 AM »
Does the negative wire from battery run directly to starter motor where it is grounded?
Offline extrafunky
« Reply #10 on: June 15, 2023, 11:41:46 AM »
The negative battery terminal is grounded to the frame at the rear right engine mount.
From this post: http://forums.sohc4.net/index.php/topic,151576.0.html
The starter motor has no ground cable. Its body is grounded to the engine.
Offline redbaron
« Reply #11 on: June 15, 2023, 01:56:59 PM »
I got it! I had the starter wire connected to batt negative. Thanks for all the replies that helped me. I have full power and spark! Turn signals are blinking very fast. Is there a relay to control the turn signals?
Offline redbaron
« Reply #12 on: June 15, 2023, 06:48:47 PM »
Calj737 has helped me for over 7 years fixing these old 550's.
