Author Topic: 2 Questions  (Read 367 times)
Offline Vintageguy
2 Questions
« on: June 20, 2023, 12:25:29 PM »
Did 1978 750F Super Sport come with an OEM fuel filter and; Does anyone know the fuel line size in mm for that model? Thanks.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 2 Questions
« Reply #1 on: June 20, 2023, 01:29:48 PM »
Fuel filter is in the tank, petcock must be removed to replace filter. They can be stubborn so I usuually slip a small pick or screwdriver between the plastic and the fuel bung until I can grasp it with needle nose pliers. Twist and pull and voila!
Fuel line is 5.5mm, fits perfect. 1/4” is a little loose for my taste.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Online newday777
Re: 2 Questions
« Reply #2 on: June 20, 2023, 03:42:05 PM »
Are you asking if it had an inline filter after the petcock? No.
As Wilbur said, filter or more precise a strainer screen in the tank, #3
Stu
My current rides
Prior bikes....
