Author Topic: Removing pipe dents  (Read 2163 times)
Offline 1080
Removing pipe dents
« on: June 20, 2023, 09:28:38 PM »
Wonder if this method could be used to headers?
Offline newday777
Re: Removing pipe dents
« Reply #1 on: June 21, 2023, 03:32:48 AM »
Have you ever lifted a 2 stroke pipe? They are a lot thinner/lighter weight steel than the headers and mufflers on our 4 stroke bikes, especially the stock 2 wall headers.
Stu
My current rides
Prior bikes....
Offline 1080
« Reply #2 on: June 21, 2023, 09:32:36 AM »
I know they are thin. and I am not talking about double wall pipes.
One of the mistakes he is doing in restoring his pipe is that he does not tapping the high spots, just like in paintless dent removeable method use to remove a dent.
If you had a rare one of a kind pipe and the condition was perfect except for one dent and you can not push the dent out because it is at the bend or just pass the bend, what method can you use?
Cut and repair and re-weld you then have to re plate the chrome.  Weld a rod in the center of the dent then heat and then pull dent out, you may have to re plate.  I watched a video where Paul Brodie straighten a dent in a bicycle tube frame  just by using a vise and wooden blocks.  I watched a video where ice was use to get a dent out in a tube or for metal shaping.  The point is what method could be used to get a dent out of a pipe with the least damage to the rare pipe? I am trying to get a discussion on methods and some useful video used in getting pipe dents out. Remember one of a kind, building from scratch makes it not an original pipe.  Conclusion safe air pressure is not enough to do pipes.
« Last Edit: June 21, 2023, 01:00:44 PM by 1080 »
« Reply #3 on: June 23, 2023, 08:14:43 AM »
 I saw a video a long time ago of a guy that used metal balls, cables and a slide hammer to drag the balls through the header and past the dent on the inside. Some of the balls (mandrels?) resembled a plumb bob, some were round. I think he made them as needed.
Offline newday777
« Reply #4 on: June 23, 2023, 09:54:11 AM »
I like that idea. I might try that on the bottom pipes of the light weight Hooker Header I have. 🤔
Stu
My current rides
Prior bikes....
Offline 1080
« Reply #5 on: June 23, 2023, 09:57:22 AM »
I will look for that video. Sounds like a good way. Thanks Don R.
Offline newday777
« Reply #6 on: June 23, 2023, 10:18:30 AM »
Post it when you find it!
Stu
My current rides
Prior bikes....
Online RAFster122s
« Reply #7 on: June 23, 2023, 11:16:31 AM »
If it gets stuck, then how will you remove it? Plan for that contingency...
Offline newday777
« Reply #8 on: June 23, 2023, 03:19:03 PM »
Hole through the ball bearing with eye hooks on both sides of the through bolt, wire cables attached to both sides to pull from and use a slide hammer when needed, in both directions. 😉
Use increasing sizes of ball bearings to slowly remove the dents.
Stu
My current rides
Prior bikes....
Offline 1080
« Reply #9 on: June 24, 2023, 05:11:10 PM »
Here's a ice method video.
Offline 1080
« Reply #10 on: June 24, 2023, 05:20:48 PM »
Pushing out dent.( car Exhaust pipe).
Offline 1080
« Reply #11 on: June 24, 2023, 05:28:29 PM »
Yoshimura motorcycle exhaust. Still looking for the ball mandrels method.
Offline 1080
« Reply #12 on: June 24, 2023, 05:35:15 PM »
Offline 1080
« Reply #13 on: June 24, 2023, 05:39:30 PM »
Offline 1080
« Reply #14 on: June 24, 2023, 05:51:24 PM »
This is to show additional tapping is needed to round up the pipe. Maybe someone would spend the time to make a miniature hydraulic gig for the their pipe?
Offline 1080
« Reply #15 on: June 24, 2023, 05:57:21 PM »
Offline 1080
« Reply #16 on: June 24, 2023, 06:04:45 PM »
Paul brodie bicycle dent removal.
Offline CycleRanger
  • No comment about being an
« Reply #17 on: June 24, 2023, 06:20:14 PM »
Getting close.
"These are my dent balls. There are 101 of them."
Offline 1080
« Reply #18 on: June 24, 2023, 06:22:52 PM »
Thin metal and not a motorcycle pipe, but I wonder if a tank dent could be removed with this method?
Offline 1080
« Reply #19 on: June 24, 2023, 06:32:22 PM »
Technique used in removing a dent is important.
Offline newday777
« Reply #20 on: June 25, 2023, 05:30:49 AM »
Some more great ideas to try to remember......
Stu
My current rides
Prior bikes....
Online RAFster122s
« Reply #21 on: June 25, 2023, 05:42:37 AM »
Air pressure in tank trying to remove dents will bow the tank out and the seams at the bottom will bulge before most dents will move. Tanks have some strong steel... People have tried it and ruined their tanks
Offline 1080
« Reply #22 on: June 29, 2023, 09:00:55 AM »
Back in the early 1980's my younger brother did the air pressure to a CB750-K2 gas tank and it was very funny how much the tank had ballooned out.  Way too much air pressure is not good.
Offline grcamna2
« Reply #23 on: June 29, 2023, 12:44:43 PM »
subscribed
Offline 1080
« Reply #24 on: July 16, 2023, 09:11:03 PM »
Again thin pipe, not motorcycle, but the method ,tools and skill used may spark ideas in restoring pipes.
