Author Topic: Yamiya Red foam group buy idea???  (Read 1855 times)
Offline jakec
Re: Yamiya Red foam group buy idea???
« Reply #25 on: July 20, 2023, 09:49:58 AM »
They are back in stock.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #26 on: July 20, 2023, 10:17:20 AM »
 My old stock seat looked a little saggy after I rode it yesterday, kind of like the Yamiya lowered seats. I'm going to have to bite the bullet and re-foam another seat. I'm glad they are back in stock and able to re-plenish their supply.
Offline jakec
« Reply #27 on: July 20, 2023, 10:19:51 AM »
Convince me to spend the $392.. tell me how bad the seat looks and that I need it
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #28 on: July 20, 2023, 11:53:46 AM »
 It looks just like mine.
« Reply #29 on: July 20, 2023, 12:07:04 PM »
That saggy, baggy look is actually one of my favorite things about the K0's...not that I have one, would love to though.  Looks like some old racer chopped the foam down to go Kawi hunting in AMA Superbike...  sorry jakec, not very convincing?
Offline jakec
« Reply #30 on: July 20, 2023, 12:43:46 PM »
Haha. I would be more happy with it, but its more sagged on one side than the other. the foam is also pretty much rock hard. But the worst part is all the foam particles coming out of the bottom holes in the seat. I had to duct tape over all of them.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline 69cb750
« Reply #31 on: July 20, 2023, 12:58:27 PM »
The foam is also pretty much rock hard
Yamiya seats are comfortable.
https://www.yamiya750.com/index.php?main_page=product_info&cPath=246_251_182_81&products_id=2360
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: July 20, 2023, 01:24:31 PM »
It was stupid money, but I really need it to restore my seat correctly……
Offline jakec
« Reply #33 on: July 20, 2023, 03:50:55 PM »
I contemplated the yamiya seat but I figured I have a nice cover and pan still, better just do it. I got the foam.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #34 on: July 20, 2023, 03:56:53 PM »
 My sandcast still has the original cover over its Yamiya foam.
Offline BenelliSEI
  • 1969 cb750
« Reply #35 on: July 20, 2023, 04:42:43 PM »
+1. My sentiments exactly.
Offline BenelliSEI
  • 1969 cb750
« Reply #36 on: July 20, 2023, 04:44:03 PM »
That is the best combo. Too bad my cover was absolutely done.
« Reply #37 on: July 21, 2023, 09:55:33 AM »
 I noticed the full K0 seat is $120 more than a red foam and shipping is the same. Of course, that seat isn't made with red foam inside.
  It was discussed on here that small pieces of red foam may be inserted in the seat pan holes to disguise a white foam. Subterfuge, I say! Sneaky? Maybe. Have I tried it? I can't recall.
Online PeWe
« Reply #38 on: July 21, 2023, 10:33:55 AM »
Is it the red foam that become like that by years and use?
Offline jakec
« Reply #39 on: July 21, 2023, 10:43:27 AM »
This bike sat since the early 80s and the foam is more smooshed on one side. So I think that something must have been sitting/leaning on it for all those years.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #40 on: July 21, 2023, 10:44:09 AM »
 It begins to crumble and sifts red sandy granules out of the holes in the seat pan. Until then it's really comfortable. The later K0's had red and yellow foam seats that also fail in a similar fashion. Ill get a pic of my older Yamiya foam today.
Offline jakec
« Reply #41 on: July 21, 2023, 10:48:13 AM »
I was about to ask you to post the old yamiya foam. My old foam is doing the sandy crumble. It was getting all over so I taped over the holes.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #42 on: July 29, 2023, 09:21:30 AM »
I got my foam the other day. It is surprisingly really heavy. So I guess the shipping cost is a little more understandable. It’s an open cell foam but it’s so heavy it gives the impression of like a gel-foam? Not sure how to describe it. It’s very dense for being open cell and has an elasticity to it. I’ve taken apart stock seats before and seen the foam which was not as dense. I guess I just expected it to be more of a 1:1 recreation, but this seems to be a more modern foam. But maybe that will be a good thing.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #43 on: July 29, 2023, 02:57:59 PM »
I had no idea there were so many pieces.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #44 on: July 29, 2023, 05:46:28 PM »
Mine is identical and when I compare it to my cover, the foam looks massive too. It will be interesting to see if it all stuffs into place!
Offline jakec
« Reply #45 on: August 03, 2023, 09:01:11 PM »
Original foam, pieces trimmed off of new yamiya foam once glued on the pan, and the finished product. It ended up fitting pretty much perfectly. The two small foam shavings are from the front corners. I used all the original tear holes in the cover aside from maybe 3-4 on the front corners which were pretty tight. I was able to use the original holes for the passenger strap and the trim as well. Overall it went on pretty easy. So I would say the foam is good. It does seem a tiny bit overstuffed at the moment but I guess if it does settle down a bit then it will be better.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline BenelliSEI
  • 1969 cb750
« Reply #46 on: August 04, 2023, 09:02:31 AM »
That looks great! What glue do you use to stick it to the pan? Did you use any kind of slip sheet between the cover and foam? Some people use a plastic bag to allow it to move around more easily.
Offline jakec
« Reply #47 on: August 04, 2023, 09:40:11 AM »
I just used spray glue, and no, no slip cover. The underside of the cover has a nylon coating on the flat part. But also if you notice on the original foam they used a dab of glue on the original seat to hold the cover in place. Pretty interesting
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #48 on: August 04, 2023, 10:03:38 AM »
 I used no glue and a slip cover of garbage bag. Here is the sandy crumble of an original seat that I procured here, it's a combo of red and yellow foam.
Offline BenelliSEI
  • 1969 cb750
« Reply #49 on: August 04, 2023, 12:18:38 PM »
Thanks for the info!
