Author Topic: 350F pistons  (Read 378 times)
Offline Wilson
350F pistons
« on: June 27, 2023, 03:16:17 PM »
While chasing the cause of low compression (80-85psi all cylinders) I found a broken bottom ring on #2 piston but what has me most concerned is the top of each piston on the exhaust side. Looks like the valve is hitting the piston but there is no sign of wear or damage to the exhaust valves. See picture.  Thanks for any input.
