Author Topic: Clutch issue  (Read 1270 times)
Offline Floshenbarnical
  • Money pit enjoyer
Clutch issue
« on: June 30, 2023, 06:34:24 PM »
Apologies if this has been posted before. My rebuilt clutch isn’t working - I followed all the instructions but the ball bearing assembly that extends when you apply rotational force via the cable is not mating with the plate underneath it when I assemble the outer cover with the lever on it. There’s a fraction of clearance that means it just rotates in place rather than extending.
I looked on Vintage CB750 to see if I’ve missed anything and there appears to be a “special angled washer 16mm” for sale. I don’t have one. I don’t remember seeing it when I took my clutch apart so if I ever had one I’ve thrown it away.
Is this my problem? Is that where it goes? Between the outer surface of the plate on top of the spring and the ball bearing assembly?
"All things change in a dynamic environment. Your effort to remain what you are is what limits you."
'77 CB750 SS
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Clutch issue
« Reply #1 on: June 30, 2023, 07:20:46 PM »
Which bike?
Find an exploded view on one of the sites, should help
1973 CB 750 K3
10/72 build Z1 Kawasaki
Re: Clutch issue
« Reply #2 on: June 30, 2023, 08:08:30 PM »
Do you mean that the lifter assembly doesn't move in and out when it rotates the full amount, or are you saying it only rotates a little bit??
Offline Doobie
Re: Clutch issue
« Reply #3 on: July 01, 2023, 02:40:54 AM »
If you mean a CB750, there is a washer, and it is slightly curved and needs to go on with the curve facing down.  Part number 90481292000. To avoid confusion, here is a link to a video that shows the part:
« Last Edit: July 01, 2023, 02:43:24 AM by Doobie »
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
  • Money pit enjoyer
Re: Clutch issue
« Reply #4 on: July 01, 2023, 05:42:08 AM »
Sorry folks. It's a CB750F2, and I have all the components installed correctly according to the numerous videos I've watched. I was informed that I can adjust the travel of the BB lifter using the flathead bolt inside the locking nut. I got it to where it's "supposed" to be, i.e. tighten it until it *just* seats and then back off 1/4-1/8 turn. It is, however, incredibly stiff and doesn't appear to be engaging the clutch correctly regardless of my cable adjustment.
 I should mention that I have the High Performance Clutch Springs from VintageCB750 installed, and having read a couple other forum posts it looks like others have had similar problems. I'm hoping it's because the springs are too stiff, and I'm hoping I didn't absent-mindedly throw the original ones away ...
'77 CB750 SS
  • Money pit enjoyer
Re: Clutch issue
« Reply #5 on: July 01, 2023, 06:53:05 AM »
Update: I did not throw away the original springs. I left work under the pretense of having left my laptop charger at home (I live 5 mins down the street) and checked my box of parts I took off the bike. Buried under the original footpeg plates were 4 oily and dusty springs. I'll replace them tonight, and hopefully that's the issue. I'll also take out the basket and double-check the order of the stack in there. If anyone knows the order or friction/ steel/ double-steel off the top of their head for an F2 I'd be much obliged. I'm pretty sure I got it right because I just copied what was already in there but you never know. The PO #$%*ed up plenty of other things.
Question: is it possible to over-tighten the bolts that hold the spring plate in place? I know there's a torque value but I can't afford a torque wrench, so I just tightened them all the way down.
« Last Edit: July 01, 2023, 07:09:53 AM by Floshenbarnical »
'77 CB750 SS
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Clutch issue
« Reply #6 on: July 01, 2023, 07:55:27 AM »
Good luck!
1973 CB 750 K3
  • Money pit enjoyer
Re: Clutch issue
« Reply #7 on: July 01, 2023, 08:40:10 AM »
Can anyone tell me how tight I should be getting these bolts that hold the spring plate in place?
'77 CB750 SS
Re: Clutch issue
« Reply #8 on: July 01, 2023, 08:57:05 AM »
 The smart ass answer is tighten them until they strip and back off a half turn. Snug and then a little more? If the spec is 5 ft. lbs imagine a 10 pound weight hanging on your 6" ratchet.
  Harbor freight sells a decent torque wrench that's cheap. I have a couple and regularly compare them to each other and my beam type old craftsman.
  The most important part is to be sure the splines line up properly so it can go together all the way, there are four possibilities, two work, two don't.
Re: Clutch issue
« Reply #9 on: July 01, 2023, 09:21:11 AM »
I have never trusted a torque wrench on those just done up tight
  • Money pit enjoyer
Re: Clutch issue
« Reply #10 on: July 01, 2023, 09:31:54 AM »
Do you mean on the plate?
'77 CB750 SS
  • Money pit enjoyer
Re: Clutch issue
« Reply #11 on: July 02, 2023, 06:04:35 AM »
Ok, original springs replaced. Clutch still fairly stiff and doesn’t appear to be engaging at all- if I put the bike in first and engage the clutch, the rear wheel still locks when I try to rotate it on the stand.
What am I missing? Can someone familiar with the F2 walk me through the rebuild process - what order the discs+ double steel discs go in, etc. I have a lot of hair but I won’t by the end of the day, lol.
'77 CB750 SS
Re: Clutch issue
« Reply #12 on: July 02, 2023, 09:33:51 AM »
Are you referring to a schematic? That will show the disc order. How many fiber discs? How many steel discs?
Can you post some pictures? Clutch basket by itself showing the top, inside of clutch cover, assembled basket. It's too easy to start mixing and matching parts and get what appears to be correct but may not be. They ALL look identical but may have slight differences you are unaware of.
Re: Clutch issue
« Reply #13 on: July 02, 2023, 10:02:38 AM »
I used a set of those on a CB750K4 rebuild one time, around 2016 or so, because I was using the shop of the company where I worked then (with their permission) after-hours.
The head head gasket leaked oil after 10 minutes of running.
I dug out my "old" Craftsman analog beam-style torque wrench (from 1969) as I tore off the whole cam assembly again to recheck torque.
The 210 in-lb setting of the Harbor Freight torque wrench showed 160 in-lbs before the nuts turned using the Craftsman analog wrench.
Then I turned the engine over and found the crankcase bolts similarly were only at 105 in-lbs before the analog wrench started turning those, which also require 210 in-lbs.
So, I had to re-open the whole bottom end to get to the rod bolts, because they turned out to be also very lightly torqued, well below spec, from the HF torque wrench.
I got another gasket set....put it all back together, and threw the [brand new] torque wrench in the dumpster. When the boss came out looking for it one day to assemble something on the machinery we were building and couldn't find his brand-new click-style torque wrench, I told him all the above. At first he was mad. Then he bought a SnapOn clicking torque wrench set - which are clearly marked "Made in China".
I never used those, either...
  • Money pit enjoyer
Re: Clutch issue
« Reply #14 on: July 02, 2023, 10:03:02 AM »
I can post some pictures, do you have a link for a schematic?
'77 CB750 SS
  • Money pit enjoyer
Re: Clutch issue
« Reply #15 on: July 02, 2023, 01:25:33 PM »
Looks like I have 6 reg cork plates + 1 cork plate with the bigger tabs, and 5 steel plates + 1 of the double steel plates. Are these missing plates causing my issue?
'77 CB750 SS
Re: Clutch issue
« Reply #16 on: July 02, 2023, 01:48:49 PM »
Nothing missing there. That's good. Eliminate that potential issue.
If you happen to have an earlier clutch cover (not the chrome "cover") in the mix it would not give you enough room and everything would be packed in too tight. I misused an earlier basket (narrower) with a later clutch pack (wider) like you have and that was too tight. Kinda hard to determine these things without one of each side by side. Same goes with the different clutch covers.
Double steel is shown as the 4th steel from the front but I have my doubts if 1 position or so would really make a difference.
It's all a process of elimination to determine if you have all the correct parts. Then it's about the assembly.
https://images.cmsnl.com/img/partslists/honda-cb750f-750-super-sport-1978-usa-clutch_bighu0058e0209_1b8b.gif
Also, If #2 is inserted into the pack 1/2 / 1 tooth off the pack will not fit together properly.
« Last Edit: July 02, 2023, 01:52:10 PM by Jerry Rxman Griffin aka MuthaF'er »
  • Money pit enjoyer
Re: Clutch issue
« Reply #17 on: July 02, 2023, 01:51:45 PM »
Should I have this much clearance?
Re: having all the parts, covers etc: Clutch was working perfectly well before I took it apart. I put everything that was in there, back in. As far as I’m aware I put it back the way it was, just with new plates.
Is there any chance it’s not moving because the motor/ sump/ tank are oil-less? Does it need to be started up and turned over to get everything operating? I just have it on the stand right now.
« Last Edit: July 02, 2023, 01:58:55 PM by Floshenbarnical »
'77 CB750 SS
Re: Clutch issue
« Reply #18 on: July 02, 2023, 01:53:00 PM »
Rotate #2  by 1 tooth and it should fit together properly. Edit - without that gap
« Last Edit: July 02, 2023, 01:57:17 PM by Jerry Rxman Griffin aka MuthaF'er »
Re: Clutch issue
« Reply #19 on: July 02, 2023, 01:54:09 PM »
Move your double steel back to the 4th steel position while you're at it from the front. That is if I'm looking at it in the proper orientation LOL
  • Money pit enjoyer
Re: Clutch issue
« Reply #20 on: July 02, 2023, 02:00:31 PM »
'77 CB750 SS
Re: Clutch issue
« Reply #21 on: July 02, 2023, 02:04:53 PM »
Not necessary.
You should be fine as long as you've used assembly lube on the bearing/rotating surfaces including the cam/cam towers.
I think you should be good to go with your clutch if you get the pack together properly. Any luck? It should all fit together with only a very slight amount of play/clearance vs that ~ 1/4" you show. The way you show it, the teeth are not inter-messing at the bottom and are on top of each other. One click and it should drop into place without that gap.
« Last Edit: July 02, 2023, 02:06:29 PM by Jerry Rxman Griffin aka MuthaF'er »
Re: Clutch issue
« Reply #22 on: July 02, 2023, 02:21:27 PM »
You mentioned you could not find the "special washer". You are probably referring to part 14 from the schematic which is at 5:40 in the hack a week video. It is not flat. It has a slight offset in the center. Be sure you have that and it is installed in the right orientation.
  • Money pit enjoyer
Re: Clutch issue
« Reply #23 on: July 02, 2023, 02:44:42 PM »
Not necessary.
Can you PM me your address so I can mail a case of beer or a bottle of wine or something
Success
'77 CB750 SS
Re: Clutch issue
« Reply #24 on: July 02, 2023, 07:25:23 PM »
LMAO. It's what we do here. I've had SOOOO much help over the years I just try to pay it forward.  That's my reward but Thank You.
