Author Topic: Old carbs, newer motor  (Read 351 times)
Offline beemerbum
« on: July 03, 2023, 08:49:57 AM »
I'm thinking of mounting  older round top carbs to a 1977 CB 750 motor. I realize the rubber parts are likely different. Has this been done? What parts would I need to source to do this?
Offline Shtonecb500
    • Youtube profile
Re: Old carbs, newer motor
« Reply #1 on: July 03, 2023, 09:26:12 AM »
you shouldn't need anything.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Scootch
  • Someday I'll know what I needed to know years ago
« Reply #2 on: July 03, 2023, 09:39:05 AM »
1 to 4 throttle cable?  Older style twist grip?
Offline newday777
« Reply #3 on: July 03, 2023, 09:46:26 AM »
Yes.
Intake boots and throttle cables are different but can be changed over. I put my K5 carbs on a K8 to test run it.
If K4 and earlier then you need to put a fuel T on and reroute the fuel lines to the left side petcock.
Stu
My current rides
Prior bikes....
Offline beemerbum
« Reply #4 on: July 03, 2023, 12:13:12 PM »
No, my carb rack is the 2 cable push pull style.  I anticipate a problem with the carb to head boots. The old carb boots look like they wont fit on the '77 head.
Offline Mr. Mike
« Reply #5 on: July 04, 2023, 07:06:00 PM »
I had this done to my ‘78 CB750.
The guy who did it knows his stuff. ‘74 Round tops. IIRC, I had to get proper isolator boots, an earlier air box and the boots for that too. All bolted up like it was designed. I still use the original two cable push pull. Toughest part was sourcing a new air box gasket. Found a gasket material nearly identical in dimension to OEM on Amazon and siliconed it in on one half.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
