Author Topic: Speedo drive washer  (Read 507 times)
Offline MARKC1982
Speedo drive washer
« on: July 07, 2023, 08:01:09 AM »
Anyone know if there is something in uk I can buy one of these?
Online bryanj
Re: Speedo drive washer
« Reply #1 on: July 07, 2023, 10:25:07 PM »
Dont think so, try asking on the uk site
Online newday777
« Reply #2 on: July 10, 2023, 12:03:26 AM »
Welcome to the forum
For what bike Mark??
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: July 10, 2023, 03:16:25 PM »
I have several old style drive units, but from memory none of the SOHC cb750 units have locating screws. What bike?
Online bryanj
« Reply #4 on: July 11, 2023, 04:33:58 AM »
None of them did, thats an adapted type for twin discs, the very first 750 had a drive plate with two tabs bent down to drive from the flats machined on the hub but this was changed to stop speedo needle waver.
There is myth going round that you need an early 500 drive plate for twin disc but all 500 are same as later 750, its the early 750 you need, long obsoleted by the way
« Reply #5 on: July 11, 2023, 07:42:06 AM »
My K6 has one like that from Motorradteile (Andy Cepok) eBay Germany.
The early bent down tabs is not an alternative when my front hub has no machined area as the earlier.
I use a later model of hub, otherwise looking the same. I used this model on my stock K6 hub too.
Not possible to order?
They have the longer bolts with nuts for dual discs too.
Offline CycleRanger
  • No comment about being an
« Reply #6 on: July 11, 2023, 07:47:46 AM »
Here's some photos of a K0 front hub showing the speedo drive piece with the bent down tabs.
