Author Topic: Front brake movement question  (Read 445 times)
Offline JDrider
  • Slowly becoming an uncertified cb550 mechanic
« on: July 08, 2023, 07:34:45 AM »
1975 cb550k1
Is the brake pad supposed to come towards the disc when squeezed and then move back away?
Correct?
Mine seem to move towards when squeezed and it’s hard to tell if it moves back away from the disc that much?
I think I already know the answer.
Is it supposed to be noticeable that the brake pad is coming away from disc brake when released?
What is my issue if it is supposed to move more?
Thanks
JD
1975 CB550K1
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Front brake movement question
« Reply #1 on: July 08, 2023, 08:05:36 AM »
It moves a tiny bit and retracts. When relaxed, you can wiggle the caliper and feel just a little bit of side to side movement. If you lift the front tire on the center stand you should be able to rotate the wheel with only a small amount of resistance or noticeable dragging. If it's tight, you have a problem. Common problems are stuck piston due to crud, stiff pivot pin due to crud and corrosion, misalignment of caliper due to improper assembly. Sometimes the brake lines collapse and need to be replaced.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline JDrider
« Reply #2 on: July 08, 2023, 08:11:34 AM »
Ok, thank you.
I’ll get the front tire up and check this.
JD
1975 CB550K1
Offline newday777
« Reply #3 on: July 08, 2023, 08:34:16 AM »
Excellent explanation 👌
Stu
My current rides
Prior bikes....
Offline robvangulik
  • Honda Fourever
« Reply #4 on: July 08, 2023, 11:49:03 AM »
The most common cause for a stuck brake piston is crud in the groove  where the o-ring resides...
Offline JDrider
« Reply #5 on: July 08, 2023, 11:51:37 AM »
After taking apart the the piston seemed to move correctly.
The brake pad just seems to stay mostly in place because it’s not attached to the piston.
So I’m guessing that happens?
JD
1975 CB550K1
Offline Doobie
« Reply #6 on: July 08, 2023, 01:17:37 PM »
A common problem is the one of the two holes in the bottom of the cup is blocked. Run a fine wire through the smaller of the two holes (the other usually isn't blocked). With the cap off, when you squeeze the lever, you should see a squirt of oil pop out of the hole.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
