And here we are. At the end of this exhaustive journey. The final end result of over 2.5 years of blood, sweat and tears. Literally. However I wouldn't change a thing. I learned SO SO SO much and that in itself was worth all the headaches. I met alot of good people along the way, in person and over the internet, mostly from this forum.
I want to take this time to give an enormous and very special thank you to Mark (Hondaman), Cal, BertJan at Outsiders Motorcycles for his outstanding product and professionalism, and Frank (Rest in Peace). There are so many more of you on this forum that have gave me amazing and helpful advice over the last few years and I will forever be thankful. Without this forum, it's threads and the people therein, I would NOT have been able to fulfill this goal and dream in the way that I have. Attaining this dream of mine is one of the top 3 greatest moments of my life. I've wanted it for so long. Some of you may think I sound silly or stupid because it's just a bike, but it's far more than that to me. My old man who went with me to get the bike back in 2009 passed away from lung cancer and he made me promise him that I would build this bike into the coolest, most badass cafe racer ever. And in my heart and mind, I've done just that.
Thank you everyone!
Below is a comprehensive list of all that was done to this bike such as engine work and frame work, as well as any and all parts I used and/or installed!
Carillo Connecting Rods
WiseCo Pistons 11.5 (836)
Super Studs (Cylinder Studs)
CX-11 Cam
New Cush Drive Bearing
Super Gasket Set (65mm)
Treated Main Bearings
Treated Rod Bearings
Adjustable Cam Sprocket Kit
Dowel Pin Kit
Super Flow Valve Set
Cast Guides
Spring Set
Primary Chains
Tsubaki Cam Chains (Cryo)
Primary Chain Tensioner
Magnetic Oil Drain Plug
Bore & Hone 65mm
Alternator Lightened and Balanced
Undercut Transmission
Cush Drive Rebuild
Combustion Chamber Blending Modification
Head Job (Both sides of head surfaced, guides replaced and reamed, valve job) -
Vapor Blasted Entire Engine and Parts
Line Lap Engine Cases
Refurbish Electric Starter
Rebuild Output Shaft
De-tabbed All Stock Tabs
Removed Triangles (Both Sides)
Cut Off Rear End
Welded Custom Rear Hoop
Welded Custom Seat Tabs
Fabricated Custom Electronics Tray
Welded Cross Member for Structure Under Seat
Richer needles currently installed are 9DZH03
Brembo T-Drive rotors
Front shocks and Brembo calipers off a 2019 Suzuki GSX-R 600
Vesrah Race Pro brake pads
Parts from CognitoMoto:
• Triple tree with stem
• Rear sets
• Sun Buchanan rims (Front and Rear)
• Woodcraft clip-ons
• LED Projector Headlight
• Motodemic headlight brackets
• Spiegler SS branded brake lines
• Custom airbox
• Bates LED taillight
• Vertical license plate holder
Most of Motogadget's electronics:
• M.Unit
• M.Lock
• Positive Battery Cable with fuse
• 3-button switches (L & R)
• M.Blaze turn signal discs
• M.Grips (Aluminum)
• M.Stop relay switch
• M.View polished mirrors
Rick's Reg/Rec
Rick's Electric Starter
Rick's starter solenoid
Antigravity battery
Velona Daytona speedo and tach (2 separate gauges)
YSS Shocks custom made
Brembo RCS19 Corsa Corta master brake cylinder
Brembo clutch lever
Mikuni RS34 Carbs
Dynatek Ignition Coils
NGK plug caps and wires
Joker Machine horn
The SumpThing oil conversion kit
Delkevic 4-1 SS Exhaust
DID 630 Chain
Avon Cobra Chrome tires
There's probably several parts and things that I'm missing, but I'll add them to the list as I remember them.
Lastly, I want to say that the only thing I have left to do on this build is fabricate the rear cowl that'll sit directly behind the seat backing. Once I get that completed and back from paint, I'll throw it on and post some updated pics, but other than that she is good to go, and I could not be happier with the end result. I did it. I built a bike.
