Hi! Both pipes and the little baskets on them look good. Still some rust but lots came out with repeated rinsing. If the filter clogs up fast then I guess the tank must come out. Now just waiting for my friend doing the carbs to get them done. Cliff.
The tank can be removed and then have a helper who doesn't mind lots of exercise,get a large container of BB's and then the two of you together roll/shake that big tank 'every which way' vigorously many times and you will have manually 'bead blasted' the rust out of it. Final rinse,and done. This procedure is strong aerobic exercise and not for the 'faint of heart'.
You'll be sore for a few days after.
![Cheesy :D](http://forums.sohc4.net/Smileys/default/cheesy.gif)
lol oh,wear earplugs
![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
I have done this before with standard size motorcycle tanks;it was the option I chose,rather than getting the tank lined.
I took about 2 hours(split up during a 36hr. time frame)of time using very vigorous shaking the tanks around in every conceivable angle;looked a bit like huge maracas Lol
and it made all the rust disappear.
I was able to get all the steel BB's out by letting them roll out the bottom(60% worth)and the rest,I used a telescoping magnet to get every last one out. The tops of the tanks also were rust free when I finished.
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
