Author Topic: Magpie's/Cliff's 1982 GL1100 "Recovery"  (Read 2603 times)
Offline BenelliSEI
  • 1969 cb750
Re: Magpie's/Cliff's 1982 GL1100 "Recovery"
« Reply #50 on: October 28, 2023, 08:52:10 PM »
They are restrictors to stop the needles from bouncing. You just roll the round "wheels" up until the needles stop bouncing or at least slow them down.  Cliff.
Do you do that with them all tied to one carb first?
Offline Magpie
« Reply #51 on: November 07, 2023, 06:27:56 PM »
No, but I suppose that would make sure each gauge is like the other. I use a bank of gauges like I do for my750's. It seems to work well and gives a nice visual. The red things are restrictors to stop the needles from twitching wildly. Cliff.
Offline BenelliSEI
  • 1969 cb750
« Reply #52 on: November 07, 2023, 06:36:24 PM »
Cliff….. I have a plastic Tee with multiple outlets. My old Motion Pro instructions insist that Step 1. is to tie all 4 gauges to ONE port first (using the tee). Adjust those clamps so all four gauges read the same. Then you know you are getting a truly even reading when you go across all four ports. Mine seems to need initial adjustment every time I use them.
     Assuming the gauges are identical and equally calibrated, no synchronization should be required. I’d be interested to hear what you see if you test them all on the same cylinder.
Offline newday777
« Reply #53 on: November 08, 2023, 01:08:37 AM »
Cool! Where did you find them?
Stu
My current rides
Prior bikes....
« Reply #54 on: November 08, 2023, 01:55:23 AM »
They look like IV metering shutoffs, but those are blue.
Offline Magpie
« Reply #55 on: November 08, 2023, 08:37:40 AM »
They came with the gauges. Cliff.
