Author Topic: 350F Alternator Puller  (Read 337 times)
Offline sfhurst
« on: July 17, 2023, 04:12:36 PM »
The shop manual calls for a "special tool", but it looks like I just need a 15-16mm fine thread bolt.  Does anyone have the exact specs for the bolt.  Thanks.
Re: 350F Alternator Puller
« Reply #1 on: July 18, 2023, 06:15:46 AM »
It is a threaded bolt type, not sure what thread
« Reply #2 on: July 18, 2023, 09:11:53 AM »
18mm thread according to the description of this tool.
Must be fine thread.
https://www.ebay.com/itm/261395567168?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8uuBLBV_Q4y&sssrc=4429486&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
Here the bolt version of M18x1.5
Probably correct.
https://www.ebay.com/itm/185416779031?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=14JQZBa-QaS&sssrc=4429486&ssuid=XgCEg0CPSya&var=&widget_ver=artemis&media=COPY
I bought a bolt for CB750.
I had to use cheap wheel impact wrench to first remove the bolt, then in with the tool. Fine thread bolt.
The alternator flew out when using the impact wrench.
« Last Edit: July 18, 2023, 09:51:46 AM by PeWe »
Offline Bodi
« Reply #3 on: July 18, 2023, 12:59:03 PM »
18x1.5. Measured the Honda tool. Actually 17.7mm thread diameter but close enough to be nominal 18mm.
Offline sfhurst
« Reply #4 on: July 18, 2023, 09:53:50 PM »
Great!  Thanks for the info.  I Googled that spec and it turns out, of all places, Ace Hardware sells a pair of lawnmower wheel bolts that have M18 1.5 threads for $4.95.  I’ll let everyone know if it works.
« Reply #5 on: July 19, 2023, 01:40:39 AM »
Sometimes the only challenge for bolts is for the threaded part be threaded far enough...
« Reply #6 on: July 19, 2023, 02:42:23 AM »
You do need HT  and not MS bolts
