Author Topic: Simple Load Test?  (Read 348 times)
Offline BenelliSEI
  • 1969 cb750
Simple Load Test?
« on: July 20, 2023, 01:09:44 PM »
Went to ride the K1 today and “deader than a door nail”. Hooked up my volt meter to the battery and 12.6 volts. Clipped on my test light and the voltage dropped to zero in about  3 minutes! Been buying these inexpensive glass mat batteries for a while now. No complaints, almost 6 years. They obviously die pretty suddenly, I rode the bike a week ago and all was good….. checked the charging system on start up and no issues.
Went for a lovely ride and then cooled off in our pond. Fantastic weather, I should be cutting grass. Screw it. Going back out this evening for “wing night” at a local bike hangout.
« Last Edit: July 20, 2023, 01:12:58 PM by BenelliSEI »
Offline jgger
Re: Simple Load Test?
« Reply #1 on: July 20, 2023, 02:09:41 PM »
Probably could have gotten a simular reading with the meter attached and a short push on the start button. Is it holding up after a charge?
« Reply #2 on: July 20, 2023, 04:17:30 PM »
113F here, I am not riding in this heat, too dangerous for heat exhaustion even using a cooling vest. Friend in Sierra Vista returned home from Tucson and Dr's visit to find his AC had died. Was able to get a technician in today to check it out. It's kaput and too old to consider the expense of a repair. They are installing a new AC system tomorrow for $7000.
Glad I don't have that kind of expense...
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: July 20, 2023, 04:42:01 PM »
I put it on a smart charger I never use and it said” dead”. I’m thinking a battery that won’t light my little screwdriver style test light is pretty much done. RIP.
« Reply #4 on: July 21, 2023, 08:16:32 AM »
Hey John... I bought this Schumacher Battery Tester a few years back, havent tried it on any motorcycle batteries but works great on auto batteries.  Dont see why it wouldnt work, will give it a try on my Kawasaki battery, it's been dead for a year [the bike is kick start and does not need a good battery to run properly]. It's a cool tool!
https://www.amazon.com/Schumacher-BT-100-Battery-Load-Tester/dp/B000AMBOI0/ref=asc_df_B000AMBOI0/?tag=hyprod-20&linkCode=df0&hvadid=312158556601&hvpos=&hvnetw=g&hvrand=2656829543451897386&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028253&hvtargid=pla-338189052226&psc=1
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: July 21, 2023, 12:24:47 PM »
Steve…. I have a cheap-o version with a strip of led lamps and this battery wouldn’t even light it!
« Last Edit: July 21, 2023, 12:27:17 PM by BenelliSEI »
