Author Topic: Please help identify this part on CB550 K1  (Read 349 times)
Offline CB750wannabe
« on: July 20, 2023, 03:12:36 PM »
It's plugged with gray sealant.  You can see a groove in the sealant from the chain.
1971 CB750K Candy Garnet Brown
http://forums.sohc4.net/gallery/28485-110112203145.jpeg
1975 CB550 K1 Candy Jade Green
Offline carnivorous chicken
Re: Please help identify this part on CB550 K1
« Reply #1 on: July 20, 2023, 03:48:50 PM »
It's a countershaft seal. When people switch over to o-ring chains it rubs against the seal, eventually causing a leak. I had a 550 that I put JB Weld over and it held it in (and a thin washer behind the sprocket to stop it from getting worse). When it leaks oil will drip down to the shifter.
« Reply #2 on: July 20, 2023, 07:07:16 PM »
Not the countershaft seal.  I just discovered that the part I'm referencing is the mainshaft oil seal.  Some previous owner put a lot of sealant over it.  And it had a o-ring chain.  I will test to see if leak is coming from mainshaft oil seal or the shift shaft seal.  Here's a pic of a mainshaft oil seal that goes behind all the gray sealant in my first photo.
« Reply #3 on: July 20, 2023, 07:48:03 PM »
Sorry, yeah, that's what I meant. If it's not leaking I'd let it go, but change the chain and or put a small washer behind the sprocket (I'm sure someone will chime in how that changes the geometry of the chain, but it worked for me for years).
« Reply #4 on: July 21, 2023, 12:48:21 AM »
Cant remenber which shaft but its a case split to change as its got a peg on it and def caused by O ring chain
