Author Topic: K8-Seat opening hits the left side cover  (Read 463 times)
Offline denward17
« on: July 25, 2023, 05:22:01 PM »
For K7/8 folks, when you open the seat, does the edge of the seat hit / rest on top of the left side cover?
Not sure if this is just an aftermarket side cover issue or not, but I might put my old OEM side cover back on to see if it hits.
The seat hitting my new side cover has marred the new paint.
Offline rotortiller
Re: K8-Seat opening hits the left side cover
« Reply #1 on: July 27, 2023, 04:20:11 AM »
Mine basically clears fine, but just touches at the front side cover end. Check the seat stop at the rear hinge as it may be at fault; you can modify it if need be to reduce the seat swing angle and save your paint hopefully. I looked at mine and I had installed a 1 inch long piece clear anti-chafe tape on the top forward edge where it just makes contact (Kisses).
« Last Edit: July 27, 2023, 04:33:00 AM by rotortiller »
Offline denward17
« Reply #2 on: July 27, 2023, 04:50:00 AM »
Thanks, I'll check to see if I have that seat stop.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: July 27, 2023, 05:27:56 AM »
Mine does the same.
Offline denward17
« Reply #4 on: July 27, 2023, 08:20:21 AM »
I attempted to adjust seat by installing 4 small washers under both brackets (under the seat, on the seat pan).  The brackets that connect the seat to the frame.
This did help a little, but the seat still touches the side cover.
I put the old side cover back on and it hits it as well.
