From the honda service manual I found this, which appears to indicate 2500RPM you should see full advance.
Next, raise the engine speed above 2,500
rpm : if the timing index mark is between
the two timing marks located at 23.5~26.5°
ahead of the " F" mark, the timing for both
idling and full advance is satisfactory.
