SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Carbs are out. Some questions.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Carbs are out. Some questions. (Read 418 times)
JDrider
Enthusiast
Slowly becoming an uncertified cb550 mechanic
on:
August 05, 2023, 07:45:00 AM »
1975 cb550k1
Removed the carbs to see why gas is getting into the oil.
Also to replace gaskets and o rings.
Where are the places on the carb I should be investigating?
Other than float height.
Also, what is the safest way to remove the float needle seat?
I don’t want to damage it.
Thanks,
Last Edit: August 05, 2023, 07:51:08 AM by JDrider
Logged
JD
1975 CB550K1
seanbarney41
not really that much younger than an
Really Old Timer ...
Re: Carbs are out. Some questions.
Reply #1 on:
August 05, 2023, 09:11:51 AM »
Are you working on carbs on the kitchen counter? Are you cleaning jets in Rye Wiiskey? lol That might be a great new tip if it works!
Logged
JDrider
Enthusiast
Reply #2 on:
August 05, 2023, 09:14:35 AM »
Ha! I did most of the disassembly outside and then brought it.
Rye is only for me.
Logged
JD
1975 CB550K1
seanbarney41
Reply #3 on:
August 05, 2023, 09:15:41 AM »
Seriously though, I would put carbs back together, go back outside, attach some kind of remote fuel supply and see where the gas is getting out of the carbs. A bench check of your fuel supply control...
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
