Author Topic: Machining new 350f upper triple tree  (Read 876 times)
Offline camelman
  • Man... Myth... Legend
« on: August 05, 2023, 09:04:01 AM »
Hi all, it’s been a few years since I’ve been here. I bought a 350f recently which has the dreaded cracked upper triple. A friend is going to machine a replacement upper for me, but I don’t have the d-washer or know where to buy one. Can someone send me thickness dimensions for a d-washer? Also, is anyone else interested in buying a350f upper triple if he makes extras? They won’t be cheap, but will get more cost effective with volume.
Thanks,
Canelman
« Last Edit: August 05, 2023, 09:17:15 AM by camelman »
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Re: Machining new 350f upper triple tree
« Reply #1 on: August 05, 2023, 09:40:07 AM »
I would assume that your machinist is not going to make triples from cast aluminum like Honda did.  I assume he is going to machine from billet.  That right there will make it much stronger and it will not require D washers.  No other manufacturer uses D washers.  Not even all Honda's use d washers.  I am not even convinced the d washers that Honda used actually serve any purpose other than to warn you not to over-torque.
If you want d-washers just for the simple true reproduction value, understood.
Offline camelman
« Reply #2 on: August 05, 2023, 11:22:47 AM »
You nailed it. I like keeping as stock as possible, hence the d washers, but doubtful we’ll keep all the pockets on the underside of the triple. Good to know possible reason for the washers!
Offline Kevin
« Reply #3 on: August 06, 2023, 06:35:04 AM »
Welcome back, Camelman!
Sent from my SM-S908U1 using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
Offline carnivorous chicken
« Reply #4 on: August 06, 2023, 07:04:38 PM »
350Fs didn't have D washers. Doesn't mean you can't use something like it with a machined replacement...
Offline camelman
« Reply #5 on: August 06, 2023, 10:17:44 PM »
CC, thanks for the reality check. I looked up the fiche on cmsnl and none are listed.
So, if it wasn’t a d-washer issue, then are the OG top bridges just a consumable unit? It seems almost all I see are broken.
Offline newday777
« Reply #6 on: August 06, 2023, 11:41:27 PM »
Maybe a torque wrench wasn't used and just plain old over tightened on the bolt(s)
Stu
My current rides
Prior bikes....
Offline grcamna2
« Reply #7 on: August 07, 2023, 01:46:24 AM »
A problem I noticed on many vintage Honda's that have the OEM cast top triple clamp with the 2 pinch bolts is:it seems they sit for a long time and then when someone goes to remove the top triple,it's kind of 'stuck in place',even though the steering stem top nut and both pinch bolts are removed;could be because of corrosion from water sitting in there and dis-similar metals between the cast alloy and steel parts.
I've seen workmen then take a hammer and repeatedly hit both sides of the cast top triple clamp,right where the pinch bolts are located;they're in a hurry to bang the part off there,plus those cast parts are hard and brittle & it doesn't take much to fracture them. A great way to remove them is spray some Liquid Wrench spray all around the points of contact,then slowly and carefully use a dull screwdriver and begin to carefully pry the cast piece between the steering stem adj. nut and the bottom of the top triple,a little at a time;slowly and No Hammer please.   ;)
« Last Edit: August 07, 2023, 01:48:23 AM by grcamna2 »
Offline Kevin
« Reply #8 on: August 07, 2023, 06:09:40 AM »
TTR400 (Kevin Bidgood) machined this one for me many years ago. He said it took over 8 hours of milling to do it.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #9 on: August 07, 2023, 07:57:23 AM »
Wow, very nice looking!
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline camelman
« Reply #10 on: August 07, 2023, 07:59:05 AM »
Kevin, is that for a 400f? I think I have the same part from TTR400. I bought a bunch of stuff from him years ago when I was is South Africa for work. He’s a fun guy to hang out with.
A friend of mine has hundreds of hours available on multi-axis mills. He’s exploring how to do it best, and is considering the multi-piece approach Calj mentioned.
« Reply #11 on: August 07, 2023, 08:41:27 AM »
Yep... I think people crank on them, overtighten, and then they just crack. They're still out there, and for less than the cost of machining one I imagine. Some folks use 400F ones as well but they are slightly different. I bought a 350F "project"/parts lot and the the triple tree was one of the first things I verified on it (as well as my recent purchase of a complete bike that I got running).
Offline camelman
« Reply #12 on: August 07, 2023, 04:49:35 PM »
Glad you found a good one. Any chance you have a spare seat pan available in that purchase? :)
« Reply #13 on: August 07, 2023, 05:01:13 PM »
Unfortunately not...
Offline Kevin
« Reply #14 on: August 07, 2023, 05:50:26 PM »
Yes, for a CB400F, but it would work on a CB350F.
This is the only one of these that TTR400 made. He made a few other styles, but I think they are all for clip on bars.
You should look through your stash...you might already have something that will work.
Offline rfndzc
« Reply #15 on: January 12, 2024, 11:13:10 AM »
Thanks,
Canelman
I’d be interested to learn more.  Did you get it fabricated? I’ve been modeling mine and was going to bring it to a machinist, looking for a result like the one posted above.
Offline grcamna2
« Reply #16 on: January 12, 2024, 12:32:48 PM »
Yeah ! !  8) 8) 8) 8)
