Author Topic: My new to me CB400F  (Read 4340 times)
Offline soonerbillz
Re: My new to me CB400F
« Reply #25 on: August 25, 2023, 05:59:05 AM »
While I'm hoping that the exhaust will clean up nicely and become a good usable part again  I know not everything turns out as planned or hoped for. So wit that thought I'm looking at options for down the road.
 Of course the most common real world fix is to have the exhaust sent off for a complete stripping and rechrome. Possible next option is a strip and high temp ceramic coating. This seems not as likely as I really want a oem look for the bike.
 Lastly would be an aftermarket exhaust.
 This where I have no experience in selection and actual performance or who even makes quality replacements.  So a little feedback would be great.
« Last Edit: August 25, 2023, 06:19:25 AM by soonerbillz »
Offline denward17
« Reply #26 on: August 25, 2023, 06:57:53 AM »
I've heard good things about delkevic, but have not seen one in the wild, nor have I used one, so take with a grain of salt.
https://delkevic.com/motorcycles/honda/1975-models/cb400f-cb400-four/
Offline newday777
« Reply #27 on: August 25, 2023, 11:53:03 AM »
Interested to see how well the Rust911 works.
Stu
My current rides
Prior bikes....
Offline soonerbillz
« Reply #28 on: August 27, 2023, 10:02:11 PM »
Well I  guess we will see if it works
This was yesterday around 4 pm
 I'm soaking the area where the worst rust was.
Offline soonerbillz
« Reply #29 on: August 27, 2023, 10:05:27 PM »
So after a little less than 24 hours here's the results of the 1st bath.
Of course as you see I could only fit a small portion of this 1 piece exhaust in the solution at a time.
But I think the solution works as well as Evaporust.
The places that had severe corrosion now have no rust but the chrome is stained. For the most part the solution absolutely removed rust and after rinsing and drying the chrome looks great!
Now to move the part into position in the tub to clean up the rest of it.
The very last pic shows how bad the rust was. The first and third pics show how well the solution works I think. They show that badly rusted section and how well it cleaned up.
« Last Edit: August 27, 2023, 10:16:46 PM by soonerbillz »
Offline newday777
« Reply #30 on: August 28, 2023, 04:11:10 AM »
That header turned out pretty good.
Stu
My current rides
Prior bikes....
Offline denward17
« Reply #31 on: August 28, 2023, 04:18:28 AM »
+1  Header looks great..
« Reply #32 on: August 28, 2023, 08:44:39 AM »
Congrats, nice find.
As you prolly know, that is an aftermarket exhaust. Too bad as the OEM 4 into 1 on the 400F is such a great looking exhaust.
I've been tempted to try the Rust911 product too, I just may do it after seeing your results. Thx for posting.
Offline soonerbillz
« Reply #33 on: August 28, 2023, 09:16:20 AM »
Ok that is news to me. It is a one piece exhaust. Every aftermarket I've seen is a component built type. Why do you say it's aftermarket?
Offline soonerbillz
« Reply #34 on: August 28, 2023, 09:46:35 AM »
Here's some pics of the collector/muffler section after it's 24 hour soak.
« Last Edit: August 28, 2023, 09:50:50 AM by soonerbillz »
Offline newday777
« Reply #35 on: August 28, 2023, 09:55:38 AM »
This is what the stock 4into1 looks like.
The muffler is separate from the header.
Stu
My current rides
Prior bikes....
Offline newday777
« Reply #36 on: August 28, 2023, 10:02:58 AM »
A couple more pictures
Stu
My current rides
Prior bikes....
Offline soonerbillz
« Reply #37 on: August 28, 2023, 10:33:32 AM »
Ok.. see that now and after looking at some on Ebay.
 Too bad .. I really learn every day.
Offline soonerbillz
« Reply #38 on: September 04, 2023, 12:18:38 PM »
Here is a few pics of my old and new rear sprockets.
 If you notice the new in has a stepped side and a flat side.
 Which way should I install it?
« Last Edit: September 04, 2023, 12:21:57 PM by soonerbillz »
Online BenelliSEI
  • 1969 cb750
« Reply #39 on: September 04, 2023, 01:02:52 PM »
Looking at both, the stepped side went “in” on the old one, so do the same with your new one. The real test is lay them both on a very flat bench with the stepped side down. The tips should line up exactly (meaning the offset from the hub is identical).
Offline soonerbillz
« Reply #40 on: September 04, 2023, 01:37:46 PM »
Kinda my thoughts as well.
 Thanks!
Offline Mark1976
« Reply #41 on: September 04, 2023, 03:48:56 PM »
   If your waiting on parts or you've got nothing else to do,  now's a great time to check/adjust the valves. Once it goes back together doing cylinders 2 and 3 become less fun.
Start with the end in mind...
Offline soonerbillz
« Reply #42 on: September 04, 2023, 07:08:19 PM »
That's actually a great idea!
 I'll get cracking on this tomorrow!
Offline soonerbillz
« Reply #43 on: September 08, 2023, 04:49:18 PM »
My evenings adventure!
Offline soonerbillz
« Reply #44 on: September 09, 2023, 02:47:48 PM »
That was a real #$%*.
 1st time doing a 4 bank of carbs. Areal learning curve adventure.
 But now all I have to do is bench set the choke and synch then they will be ready to install.
Offline soonerbillz
« Reply #45 on: September 11, 2023, 09:54:20 AM »
Put on the new rear tire today
Offline soonerbillz
« Reply #46 on: September 11, 2023, 12:57:02 PM »
Making progress!
Offline soonerbillz
« Reply #47 on: September 11, 2023, 01:00:20 PM »
FYI: If you buy inexpensive of the JT aftermarket rear sprockets you might have to grind down the back lug of the sprocket studs. The JT raised section is a bit wider than factory.
« Last Edit: September 11, 2023, 01:07:19 PM by soonerbillz »
Offline grcamna2
« Reply #48 on: September 11, 2023, 01:11:24 PM »
I had that same issue before;I used a Dremel and ground the four bolt hole 'shoulders of the sprocket instead so I could save the special bolts for when I wore out that sprocket.
Offline soonerbillz
« Reply #49 on: September 18, 2023, 01:09:22 PM »
Been a bit of starts and starts on the bike lately.
 I did get the carbs finished and ready to install. Started more assembly and then found the kicker would turn the engine over. I freaked out thinking the engine locked up some how. This led to a day of frenzied tear down only to find out the previous owner had removed the clutch. I guess to replace the disks and in doing so pulled the kicker shaft.  Then they installed it incorrectly so as the thing wouldn't engage the gears properly 🙄
 After getting all that corrected and putting everything together I turned to reinstalling the electrical parts and harness.  There were some minor issues to fix and I ended up ordering a new fuse box as the original obviously was smoked at some point.  They had connected a 15amp breaker in place of the burnt main fuse!.
 Battery box installed, manifolds installed and rear brakes completed.  Footings and shifter installed.
  Next I'll complete the electrics  and install the carbs and new cables
« Last Edit: September 18, 2023, 01:16:09 PM by soonerbillz »
