Author Topic: GL1000 question  (Read 811 times)
GL1000 question
« on: August 06, 2023, 12:04:31 PM »
Asking for a friend.
GL1000:
- in 300 mile she loses about quart of coolant
- white smoke from the exhaust, smoke does not stink
- no water in oil, no oil in coolant
- hard to start almost a minute when cold
We suspect the head seal - metal ring around the cylinder.
Opinions?
Offline grcamna2
Re: GL1000 question
« Reply #1 on: August 06, 2023, 12:40:53 PM »
Prokop,what do the 4 spark plug colors look like to you ?
Offline newday777
Re: GL1000 question
« Reply #2 on: August 06, 2023, 12:50:58 PM »
Yes most likely head gaskets.
Any really clean spark plugs compared to the others?
Stu
My current rides
Prior bikes....
Offline BenelliSEI
  • 1969 cb750
Re: GL1000 question
« Reply #3 on: August 06, 2023, 01:07:48 PM »
Headgasket would be my first guess, seeing white smoke. Know anyone with one of those testers that goes in place of the rad cap and then you use a manual pump to pressurize the system. That usually tells the tale…..
Also, check the coolant pipes under the carbs. They have large “0” rings at the ends where they connect. If they “drool” under pressure, the coolant can dry up on a hot motor and create a mystery.
And, look at the water pump design.the shaft has numerous seals that separates the oil in the crankcase from the water in the pump. Water in the crankcase does not always mean a headgasket! Could easily be those ceramic seals.
Finally…… check the coolant overflow tank for leaks too. They do crack and leak at +50 years old….. Good Luck!
« Last Edit: August 06, 2023, 01:09:36 PM by BenelliSEI »
Re: GL1000 question
« Reply #4 on: August 06, 2023, 03:25:46 PM »
Thank you, gents.  I will pass it on.
Re: GL1000 question
« Reply #5 on: August 07, 2023, 05:22:39 PM »
Is there a shop manual available for download somewhere?
Offline Johnie
Re: GL1000 question
« Reply #6 on: August 07, 2023, 06:16:53 PM »
Find an online manual at goldwingdocs.com
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: GL1000 question
« Reply #7 on: August 08, 2023, 01:57:23 AM »
Thank you, sir.  :)
Re: GL1000 question
« Reply #8 on: August 17, 2023, 03:01:52 AM »
Here is the gasket, you can see where it leaked.  Do you think it was tighten too much?
Anything you can tell from the picture?
Offline BenelliSEI
  • 1969 cb750
Re: GL1000 question
« Reply #9 on: August 17, 2023, 05:02:08 AM »
Just looks old and corroded! Any corrosion tracking on the head or block? Clean it up and put in a new one.
