Support the site. Your contributions keep this site running.
So many different options. PO sent me this. Hopefully I can find some locally. He just did oil and filter……
Quote from: BenelliSEI on August 10, 2023, 08:07:21 AMSo many different options. PO sent me this. Hopefully I can find some locally. He just did oil and filter……That's different than what you originally mentioned..Looks great.Yes…. I misunderstood him yesterday. He sent a pic this am!
Quote from: BenelliSEI on August 10, 2023, 08:07:21 AMSo many different options. PO sent me this. Hopefully I can find some locally. He just did oil and filter……Does the label say anything about 'wet clutches'? I know the Mobil 1 "V-Twin" oil is a bad idea in the SOHC4 engines. Same for the Valvoline equivalent (which turned my gearbox into a 2-speed in less than 12 miles' runtime - couldn't hardly even reach 3rd gear!).
Oh boy, an oil sermon, pull up a chair.I use Dino oil in the K3 designed for wet clutch engines. I’ve used Valvoline and NAPA and Castrol, have not had issues.
Quote from: MauiK3 on August 13, 2023, 02:11:16 PMOh boy, an oil sermon, pull up a chair.I use Dino oil in the K3 designed for wet clutch engines. I’ve used Valvoline and NAPA and Castrol, have not had issues.Me too. Castrol 4-stroke motorcycle 10W-40 is in all my bikes. Apparently the Varadero has been on this stuff forever, so assuming I can find it, will probably carry on.
I'm sure the manual for that engine says 20/50 semi synthetic. I use Castrol.
Quote from: scunny on August 28, 2023, 11:26:49 PMI'm sure the manual for that engine says 20/50 semi synthetic. I use Castrol.The owners manual just calls for a regular 10/40 motorcycle oil. I use Castrol 4T in everything else around here, so it may get a change if I can’t find that other stuff for less than $25/litre!
