Author Topic: 1975 CB750K Clutch Question  (Read 353 times)
Offline John G
  • A 1975 CB Rebuild
« on: August 24, 2023, 09:51:24 PM »
So I have 7 friction plates and 6 steel drive plates. Do I need anything else in there? also I don't have the washers No 9 in the attachment. Do I need those?
John G.
Re: 1975 CB750K Clutch Question
« Reply #1 on: August 25, 2023, 07:12:26 AM »
That model is a very early one when washers were used.
Check CMSNL chart for your model and year.
Offline John G
  • A 1975 CB Rebuild
« Reply #2 on: August 25, 2023, 08:48:58 AM »
Good news is always appreciated. Now I can finish the reassembly not worried I may be missing something. Cheers.
John G.
Offline gunr
« Reply #3 on: August 25, 2023, 11:36:28 AM »
Make sure the grooves are oriented to spin the oil out from between the discs and also place all the steel plates so the sharp edges are all facing the same direction.
I put mine the correct way on the drum but when inserted into the basket they were reversed.
Grooves face this way in the basket\\\\\.
