Author Topic: ST-2 Brake Module Installation  (Read 1447 times)
Offline BenelliSEI
  • 1969 cb750
« on: September 07, 2023, 05:48:53 AM »
Received this item yesterday. Plan to install it today. Interesting idea, Made in Slovenia! The clips supplied are nice enough I plan to use them. They are sealed with gasket material and once clipped on to the wires (ground, power and brake signal) the male spades on the module just plug in. My Canadian spec Honda Varadero has the lights on full time, so easy install?
In theory, any significant deceleration will simply apply the brake light.
« Last Edit: September 07, 2023, 10:01:57 AM by BenelliSEI »
Re: ST-2 Brake Module Installation
« Reply #1 on: September 07, 2023, 07:29:57 AM »
Following.
Offline Schnell
« Reply #2 on: September 07, 2023, 08:11:11 AM »
I am aware and interested in this as well.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: September 07, 2023, 09:56:51 AM »
Just finished up. Super easy and tidy installation, despite the Varadero having a lot of “electronics” packed in behind the taillight. Used their connectors and they worked really well. Slipped a small piece of bicycle inner tube over the three connectors and zip tied both ends.
Will take pictures next trip to the shop. I didn’t permanently mount the box (peel and stick Velcro comes on it). The guide suggests you can alter “sensitivity” by adjusting the forward tilt or rake. Playing with the box after completing the wiring confirms it’s a pretty simple inertia switch. It just energizes the brake light on decel. No flashing or added bling. I’m a big fan of KISS, so fine by me. On any of my SOHC cb’s this would be a 10 minute install. Only change would be to add a fused and dedicated power lead, so it would work even if the lights are “OFF”.
« Last Edit: September 07, 2023, 09:59:14 AM by BenelliSEI »
Offline Schnell
« Reply #4 on: September 07, 2023, 05:09:57 PM »
I would be slightly more interested in the unit with flashing response upon deceleration.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: September 08, 2023, 05:07:12 AM »
Frank….. I think they sell those too, some I saw were even “programable”. I bought the plainest (cheapest) version. Went for a ride last night and a friend reported it seemed to flicker or flash when not really required. The only adjustment on this unit is the angle it sits on. All the under seat plastic and framework on the Varadero is raked steeply forward, so will need to shim the nose of the unit up a bit. Pictures later…..
Offline BenelliSEI
  • 1969 cb750
« Reply #6 on: September 08, 2023, 07:30:52 AM »
Measured the angle of the control unit using my “Tilt-Box”. It’s sitting at 5.8 degrees, nose down. Added a small 3/16” shim under the nose and raised it to 3 degrees, still a bit nose down. The bike “tail sags” a bit when I’m on it, so will test this angle, next time someone is following.
« Last Edit: September 08, 2023, 07:33:12 AM by BenelliSEI »
Offline Schnell
« Reply #7 on: September 08, 2023, 11:38:17 AM »
Just ordered one. Watched a couple of videos and learned that by mounting it upside down, you get the multiple flashing.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: September 08, 2023, 06:29:29 PM »
That’s interesting. No mention of that in the instructions!
Offline Schnell
« Reply #9 on: September 08, 2023, 06:53:01 PM »
I learned that in this video, at the 6 minute mark.
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline BenelliSEI
  • 1969 cb750
« Reply #10 on: September 08, 2023, 06:58:12 PM »
Thanks!
Offline BenelliSEI
  • 1969 cb750
« Reply #11 on: September 10, 2023, 09:05:46 AM »
Went for a good long ride today, with two buddies. Both noted the brake light is still flickering constantly. Obviously, 3 degrees of rake on the  control box (nose down) is still too much. Will make up a 1/2” shim and see if that gets it level. In fairness, that’s what the instructions suggest.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #12 on: September 10, 2023, 02:33:22 PM »
Very cool, sort of a brake switch you don’t need to think about.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #13 on: September 10, 2023, 03:25:43 PM »
Steve….. Exactly. When I downshift through the gears, the Varadero virtually pulls itself to a stop. I need to constantly remind myself to pull the lever and show a light. Hopefully (when I get it set properly) the “box” will remember every time.
Offline BenelliSEI
  • 1969 cb750
« Reply #14 on: September 12, 2023, 08:25:47 AM »
This thing may be defective! None of my adjustments are making any difference. This may turn out to be a waste of time and money?
« Last Edit: September 12, 2023, 05:59:07 PM by BenelliSEI »
« Reply #15 on: September 12, 2023, 08:32:53 AM »
Do you ride in heavy traffic where you think this is necessary?
« Reply #16 on: September 12, 2023, 08:41:09 AM »
John, talk with the folks at ST Systems, they can help.
Offline BenelliSEI
  • 1969 cb750
« Reply #17 on: September 12, 2023, 09:54:50 AM »
Email has been sent.
Offline BenelliSEI
  • 1969 cb750
« Reply #18 on: September 12, 2023, 09:55:44 AM »
Yes. Very occasionally in places where traffic is heavy and most are on their phones!
Offline BenelliSEI
  • 1969 cb750
« Reply #19 on: September 12, 2023, 05:57:50 PM »
Well….. one more mounting attempt (on advice from ST2), but they also sent this. May need another unit!
Okay, please let me know. Maybe it is a faulty unit
Kind regards,
Philippe Duvón
ST2 Support
support@st2-systems.com
« Last Edit: September 12, 2023, 05:59:44 PM by BenelliSEI »
« Reply #20 on: September 12, 2023, 07:59:36 PM »
They will replace it if it won't work, so you won't be out your money. If it simply doesn't work for your bike, you return it and money back ..
Not fun, but fair.
David
Offline BenelliSEI
  • 1969 cb750
« Reply #21 on: September 13, 2023, 05:59:15 AM »
Not fun, but fair.
David
David…… it works fine when I tip the control box forward and backwards, but there is a strange “clinking” noise from inside. When I told the tech about the noise is when he suggested it might be faulty….
« Reply #22 on: September 13, 2023, 08:49:19 AM »
Might have had a big drop in transit that has caused it to have the issues.
Offline BenelliSEI
  • 1969 cb750
« Reply #23 on: September 21, 2023, 11:58:31 AM »
On our 1,060 kilometre ride last weekend, the brake controller flashed on and off when ever it felt like it! Fortunately the lights work normally when I use the pedal or lever, so no problem. Contacted ST2 and they have mailed me a new one.Their tech agreed that mine is “faulty”.
« Last Edit: September 22, 2023, 07:39:40 PM by BenelliSEI »
« Reply #24 on: September 21, 2023, 09:17:59 PM »
Sorry you had a bad one initially. You can cut open the old one and take a gander at the guts if so inclined. Figure they potted the board, I wonder what is bouncing around inside, clearly something important.
