Author Topic: 73 CB750K plug fouling / Exhaust restriction  (Read 378 times)
Offline mrmach5
  • 75 Honda 550k, 78 750K, 80 750F, 83 1100F
« on: September 17, 2023, 10:46:46 AM »
I'm battling some carbon plug fouling on #1 and 4 . 2 and 3 look great.
Good compression , stock air box, electronic ignition, timing spot on, 105 main jets, 35 pilots needle in the 3rd slot. Bike runs nice and idles good but after a short test drive I can tell those two plugs are fouling and will only get worse. Seems like its right around 2200 rpm where there is the slightest hic-up.
I've replaced the coil, firing 1 & 4 , new wires and plug caps as well. ND X22ES-U plugs. All four carb idle mixture screws are at 1 turn out.
Nothing I seem to try seems to have any effect. So crazy question , the exhaust is a brand new Italian made HM300 reproduction 4 into 4  set.
If there were too much restriction, causing excessive back pressure, could that contribute to the plug fouling? I could remove the baffles on those cylinders to see if it has any effect?
Re: 73 CB750K plug fouling / Exhaust restriction
« Reply #1 on: September 17, 2023, 12:38:01 PM »
Carbon fouling usually indicates a carburation problem: too much fuel/too little air.
Please post pics of your spark plugs.
Offline Mark1976
« Reply #2 on: September 17, 2023, 01:51:55 PM »
+1
Start with the end in mind...
