Author Topic: Wiring harness ?  (Read 700 times)
Offline creed
Wiring harness ?
« on: September 18, 2023, 05:20:38 AM »
Hello ladies and Gents,
     My question is can I use a cb500 wiring harness for a cb550 and should I? Thanks, and much appreciated!
Offline calj737
  • I refuse...
Re: Wiring harness ?
« Reply #1 on: September 18, 2023, 10:37:07 AM »
They’re pretty similar but depending upon model year of the 550 and the market (US, EU, etc) there are differences. Also, the connectors under the left side cover for the 500 are sometimes round, but always rectangular on the 550. You can swap the connectors as the wiring is still consistent.
Almost all differences can be overcome with a bit of fiddling.
Offline creed
« Reply #2 on: September 18, 2023, 12:39:35 PM »
So should I just stick with the 550 harnesses? what items are you losing by going with a 500 harness? thank you for your time. This is my first build so it's a little nerve wracking.
Offline calj737
  • I refuse...
« Reply #3 on: September 18, 2023, 02:03:33 PM »
What year is your 500, and is it a US model? What year donor harness are you looking at?
And again, it can all work, you just might not have a “plug and play” situation. Compatible, yes, but might require some adaptations.
Offline creed
« Reply #4 on: September 19, 2023, 05:10:39 AM »
1974 cb550 US model but would like to simplify it and was told a cb500 harness would work fine. Thanks for response.
Offline calj737
  • I refuse...
« Reply #5 on: September 19, 2023, 05:45:14 AM »
A 500 harness will work, except you may have the round connectors for the left side panel. Can you explain what “simplification” you are intending.
Offline creed
« Reply #6 on: September 19, 2023, 12:16:34 PM »
Neutral safety relay gone for sure, tach and speedo combined and I'm not sure if I am going to go with a single led taillight with all functions in one light. I am also getting rec/reg together. Thanks again for your reply
Offline calj737
  • I refuse...
« Reply #7 on: September 19, 2023, 01:40:30 PM »
I’m not sure I’d eliminate the Neutral Safety. There are far too many folks (beginner and experienced) that have dropped bikes by pushing the electric start while in gear.
Might give that a second thought…
Offline creed
« Reply #8 on: September 19, 2023, 03:17:14 PM »
I will reconsider and will look into options as far as a wiring harness. I would like to go with the mu unit, but man those are expensive. Thanks for the input! I'm sure I will be bothering you again. :)
