I was working on altenator wiring and had my bike proped on the right side on some tires. When I finished and straighten it up, a few tablespoons of oil came out of the points cap area. Is that area connected to oil. Also, strangely, the is a small hole in the case about a 1/4" in from the edge that connects to the cover. I'm checking the cover to see if leaning on the tires might have deformed it but it looks ok. Ordered a new gasket which I will Permatex in hoping that will seal it. Should I put a small screw in the hole to seal it.
