Author Topic: Cb400f fuel question  (Read 744 times)
Offline soonerbillz
« on: September 20, 2023, 01:15:40 PM »
How much fuel should a properly adjust float bowl hold?
Re: Cb400f fuel question
« Reply #1 on: September 20, 2023, 07:30:46 PM »
Normally, if you take the float bowl off while it is full it will be 2/3 of the depth of the bowl. This depth is controlled by the little float valve at the tang on the back of the floats, and by how clean and well-sealed the float valve is with its seat.
Some here will recommend the "clear tube" method: if you go that route, the fuel level should be 2-3 mm below the top of the float bowls when sitting on the bike with the gas ON and the fuel tank above the RESERVE level.
Offline Deltarider
« Reply #2 on: September 21, 2023, 12:33:32 AM »
Do my method and report your findings for the benefit of all CB400F owners here. The CB500/550s with oldstyle carbs should have around 50ml. The CB400F somewhat less.
CB500K2-ED Excel black
