Author Topic: Cb550k shifting up but not down  (Read 454 times)
Offline bert1
« on: September 20, 2023, 04:12:17 PM »
75 550k, and I notice that the it's very very difficult to downshift, especially from 2nd into 1st. but shifting up is smooth.
The clutch slips as well, as I didn't change the friction plates and springs when I went through the engine.
P/o put 20k on it many years ago, sat for a while. Even when rocking the bike back and forth, the bike stays in 2nd or 3rd especially after riding in that gear for a little, it's very difficult to shift down at all, it helps a little if the bike isn't running. Once i get it to click down, shifter does not stick.
So i'm confused as to why it shifts up nicely but sometimes won't even go from 4th into 3rd without pulling over and rocking the bike for 2 minutes. Is this all caused by the clutch/ springs being worn?
Offline newday777
Re: Cb550k shifting up but not down
« Reply #1 on: September 20, 2023, 05:43:23 PM »
What oil are you using?
Stu
My current rides
Prior bikes....
Offline brianc
« Reply #2 on: September 20, 2023, 09:26:12 PM »
Carefully look at the clutch centre for wear. The steels wear dents into the alloy and it won't release properly. My F2 750 did that, gear changing and selecting improved significantly after I did a bit of rework on it. I have a new centre to fit when I get a chance.
« Last Edit: September 21, 2023, 02:26:11 AM by brianc »
Offline bert1
« Reply #3 on: September 21, 2023, 08:21:57 PM »
Worse than i thought, fibers were 2.55mm thick on avg so they wore into the metal fingers. Caught it early so i'm happy. As for the poor downshifts, the spring on the shift shaft had an odd gap on it, so it wouldn't engage with the downshifting mechanism.
« Reply #4 on: September 22, 2023, 12:15:40 AM »
That spring needs replacing
Offline bert1
« Reply #5 on: September 22, 2023, 09:37:34 AM »
It was crossed in an "x" put it back parallel tension is fine. One of the dumber things ive done.
