Author Topic: Blowing main fuse?  (Read 1582 times)
Offline calj737
  • I refuse...
Re: Blowing main fuse?
« Reply #25 on: September 24, 2023, 02:18:15 PM »
It was the flasher. The new one required a ground connection, which had come loose and was flopping around inside the electrical panel. It must have been intermittently causing a short. I replaced it with the old mechanical one and everything is great now. Problem solved!! Thanks for all the help everyone!
Going to go put a hundred miles on it today, be right back ;)
The stock flasher also requires a Ground. There should be GREEN, BLACK and GREY wires to it. If the ground wire were loose, it flapping around and touching bare metal would not blow the fuse, but it could cause dodgy indicator performance. But, if the loose wire was a powered wire flapping about, if it were to touch bare metal that could cause a fuse to blow.
So what color wire was loose?
Offline joegeis
  • '78 Honda CB550k
« Reply #26 on: September 24, 2023, 03:33:30 PM »
maybe its not the original one then. it is only 2 prong, and it is not electronic. There is a what I thought to be a "spare" ground tucked away.
The loose wire was from my new electronic relay. The relay has the two prongs, but also a 3" long black "ground" wire.
Either way, the issue is resolved! The old flasher is actually working great now. Maybe my battery was low, or it was just tired before, lol. It was taking a few seconds to begin flashing after hitting the switch. I also thought I might go LED at some point, so I replaced it. I'm no longer planning to go LED, so the old school one works for me.
Offline grcamna2
« Reply #27 on: September 24, 2023, 04:21:27 PM »
The black wire/s are power + wires,not ground - wires.
Offline calj737
  • I refuse...
« Reply #28 on: September 24, 2023, 06:40:24 PM »
To be clear, my point was the flasher would not be the culprit to your MAIN fuse blowing. Sure, correcting the wiring would resolve your indicators, but I don’t see the connection to your original, primary issue.
Offline joegeis
  • '78 Honda CB550k
« Reply #29 on: September 24, 2023, 06:45:51 PM »
Maybe I was mistaken about how it was wired or what color was loose, because swapping out the relay definitely solved the fuse blowing issue.
« Reply #30 on: September 24, 2023, 06:54:32 PM »
No it doesn't, it's a two terminal type. People are always asking what the extra green wire is next to the flasher...
Offline calj737
  • I refuse...
« Reply #31 on: September 24, 2023, 07:51:01 PM »
Per this diagram it is a 3-wire on the 550.
Offline Deltarider
« Reply #32 on: September 25, 2023, 07:31:27 AM »
Dunno why you had to present that diagram. As if we aren't having enough problems coming from that Clymer manual. Anyway, here's the correct wiring diagram for OP's model. The winker relay in that model - CB550K4 - had only two prongs connected: Black and Grey. Cf. p.96 in: http://manuals.sohc4.net/cb550/owners_manual/OM55078.pdf
CB500K2-ED Excel black
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #33 on: September 25, 2023, 07:44:15 AM »
Good job
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline BenelliSEI
  • 1969 cb750
« Reply #34 on: September 25, 2023, 06:31:24 PM »
Good job
Interesting…… As usual, the first question we should ask is “what did I do (or change) to cause this new problem??” . Odd how often I end up pointing my finger back at myself!
« Last Edit: September 25, 2023, 08:22:11 PM by BenelliSEI »
