Author Topic: Shipping an engine  (Read 596 times)
Offline gary p.
Shipping an engine
« on: September 21, 2023, 08:52:44 AM »
I’m going to ship a ‘73 cb500 engine for a rebuild.  I’ll check the usual options, UPS, FEDEX, DHL…   I’m wondering if anyone has a best/better suggestion.  I’m not even sure ups or fedex will carry the weight.
Who have you used?
Re: Shipping an engine
« Reply #1 on: September 21, 2023, 09:32:22 AM »
Offline calj737
  • I refuse...
« Reply #2 on: September 21, 2023, 10:15:03 AM »
Where are you shipping it is the big question? And, are you disassembling any of the motor? This makes it much less expensive and better options for shipping.
Pack and ship the head separately. Then the cylinders. Then the lower case with the pistons/rods out. Wrap and label each of these for original location so the machine shop can mic' them once they get them. It also makes the case a more "usual" shape and less weight.
« Reply #3 on: September 21, 2023, 12:17:47 PM »
 I'm told Fastenall will ship small pallets store to store.
« Reply #4 on: September 21, 2023, 04:41:14 PM »
Avoid UPS and Fedex if possible. Expensive, and they (and XPO Logistics) have lost engines for weeks on end coming to me. UPS actually destoyed one 550 engine enroute to here.
My go-to is R&L Carriers. They hire almost totally only careful vets, and they have been on-the-ball with every delivery to/from here. Nothing lost, nothing broken, on-time (except during Covid, they were late a couple of times for lack of workers).
Old Dominion is my next-best choice: sometimes R&L doesn't go where you are. Both have tailgate services available for a small extra charge, too.
Offline Mark1976
« Reply #5 on: September 21, 2023, 08:23:31 PM »
   Fortunately your in a good lane for ground freight, lots of trucking in the NE. 1st question becomes how far do you have to ship it. 2nd question is how far is your destination located from your destination terminal,  if its too far away from a terminal, the carrier will interline it with a secondary trucking company and that adds to cost and the amount of time it'll take to deliver in either direction.  Ask the carrier if they'll give you a better rate if you bring it to them and pick it up from their dock. It used to make a difference, but these days probably not,  can't hurt to ask.
   The farther its gotta travel to the destination the more handling its going to encounter which is where damage and the possibility of it getting lost starts to come into play. If you can put it in a good wood container and then attach it to a pallet it'll stand the best chance of survival, and then use the same container on the return trip. It'll make handling and protecting the engine that much better. Lift trucks and pallet jacks are the back bone of the LTL industry,  if its not on a pallet, it'll get kicked around until it gets damaged, lost and then delivered...
   So yeah,  shipping an engine no matter how you do it, isn't cheap nor will it be easy. The cost of freight could well equal the cost of building the engine.
Start with the end in mind...
Offline newday777
« Reply #6 on: September 22, 2023, 04:55:09 AM »
Who have you used?
You are in Chicopee? Take it to MikeR in Boston(member here)
Stu
My current rides
Prior bikes....
Offline Mark1976
« Reply #7 on: September 22, 2023, 05:50:28 AM »
+1
Offline carnivorous chicken
« Reply #8 on: September 22, 2023, 11:51:27 AM »
I've used both U-ship and Greyhound. My last couple of transactions with U-ship have been a little tough, but the more flexible you are with time (for pick up and delivery) the cheaper it gets. I haven't used Greyhounds in a few years but they were great when I was in PHX for shipping to other big cities. You have to pack it and bring it to them, and someone has to pick it up at a station.
